20 Most Recent Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Questions & Answers
2answers
Bosch washer spin only
Had a repair man here for the same issue. Learned two things:
1. Too much detergent causes 'soap lock.' The electronics will get confused when there's too many suds left after a rinse and shut the spin cycle down. That's why re-running the entire cycle without more detergent solves the problem. Use less detergent.
2. There is a way to manually get the spin cycle to run using diagnostics codes. Here's what my guy did:
a. Washer selection knob in OFF position.
b. Hold the 'Spin Selection' and 'Delay Start' buttons down at the same time.
c. While holding those two buttons, turn the Washing selector knob to Permanent Press-Cold.
d. Keep the buttons held down until the LCD control panel reads 'P:01'
d. Release buttons.
e. Use the 'Spin Selection' button to cycle thru the codes. Stop when it reads 'P:04' which is the spin cycle.
f. Press 'Start/Pause' button to begin the spin cycle.
I don't know what the other codes do but this should save you from having to run the entire wash cycle.
Hope that helps! Tim
1/29/2023 3:11:20 AM • Bosch 3.81 cu ft... • Answered on Jan 29, 2023
3answers
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
1/7/2019 4:48:41 AM • Bosch 3.81 cu ft... • Answered on Jan 07, 2019
Bosch 500 Washer not spinning at high rotation
Bottom right handside is a small window open it and u screw filter out to clean fluff and sometimes coins. Usually is the prob
2/6/2018 9:04:03 PM • Bosch 3.81 cu ft... • Answered on Feb 06, 2018
I have a Bosch front loader washer. It has begun leaking water out of the bottom, and often will not run through a full cycle, but we sometimes get lucky. I tried it today and 5 mins into the cycle
You have to inspect water outlet from the drum. When it starts filling water, water leaking out at the same time. So computer sees, thet water level is not going up, so it stops. You should call service, or if you have someone, who ca open and see. Some times you can find it yourselves
12/3/2017 11:15:45 AM • Bosch 3.81 cu ft... • Answered on Dec 03, 2017
4answers
Bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
12/14/2015 9:25:57 PM • Bosch 3.81 cu ft... • Answered on Dec 14, 2015
2answers
We have a mildew smell from our Bosch front load
I am not sure about the dry detergent, but you have to leave the door open after you are done with your loads. Wipe the inside rubber ring out and wipe the door down. It needs to stay open until it is completely dry.
8/5/2015 4:09:27 PM • Bosch 3.81 cu ft... • Answered on Aug 05, 2015
2answers
I have a front loading bosch washing machine and
Hi harleyd81899,
F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter. Also check water pressure is not too low If all these test ok you need to run a load with no clothes with 1 cup of white vinegar this will solve your issue.
Regards
R.K.
1/2/2015 10:04:37 PM • Bosch 3.81 cu ft... • Answered on Jan 02, 2015
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
11/16/2014 5:43:45 AM • Bosch 3.81 cu ft... • Answered on Nov 16, 2014
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
240 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
bosch frontload washer will not drain
  • Washing Machines
