Washing Machines Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The machine is wobbling during the spin cycle. I've re-balanced the machine and that didn't help. I've ran the spin cycle without clothes in the drum and it still wobbles. Any suggestions on what the problem is or how to fix this would be greatly appreiciated.
  • yugo555 Oct 20, 2009
    As I was removing the inner basket I discovered that the upper balancing ring on top of the inner basket has been wearing away at the casing on the upper part of the outer drum. I have a spanner tool to remove the center bolt so just removed the screws surrounding the bottom part of the inner basket and removed it that way, this proved to be fruitless as there was nothing to see underneath and putting everything back together didn't stop the machine from wobbling and making plastic on plastic rubbing noise. Do I need a spanner tool to get that bolt off, I'm not sure what to do next?
    I DON'T have a spanner tool.
Poppa Maddo
Level 2:
Sergeant:
  • Expert 372 Answers
  • Posted on Oct 19, 2009
Poppa Maddo
Expert
Level 2:
Sergeant:
Answers
372
Questions
0
Helped
118783
Points
687
The inner tub is not seated correctly. It must be disassembled and repositioned then fully tightened again.
1helpful
3answers
Fisher and paykel model gw712 . During rinse or spin cycle unit goes out of balance and stops. The rince or spin light flashes and a beeping sound is heard.
your clothes load is too heavy on one side; stop it move some around and turn it back on and see if it doesn't wobble all over.
Washing machine
check lid isolation switch. check for balance of clothes. I would go for the lid switch first. The balance second as if it starts to spin and wobbles violently it will switch itself off to prevent damage and you will have to move the clothes around to balance the drum.
1helpful
3answers
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
2helpful
2answers
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
4helpful
Maytag washing machine gets out of balance
Could be broken suspesion leg or spring securing the drum
4helpful
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Top Washing Machines Experts
john h
