I have a PSC 1500 series HP printer/copier/scanner. like others, the printer prints a test page every time I turn the printer on. when I scan the test page as recommended I get the following error message and so I'm still stuck with the problem.
''Pen Alignment Failed due to an incorrect page being in the Scanner.''
any advice appreciated
thx
frank
SOURCE: need to install printer HP PSC 1500 all-in- One series
How do I install my HP 1500 series on my Vista computer from disk. I will not let me "run as"
SOURCE: printer (psc 2200) does not
To bypass the cartridge alignment problem
Try the following
Thanks for using Fixya
SAM ANDERSON
SOURCE: hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document.
Method one: Scanning with Windows Photo Gallery
Method two: Scanning with Windows Fax and Scanning
NOTE:
This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
Method three: Scanning with Paint
SOURCE: installed new black ink cartridge in HP PSC 2110
Did you check the print.
Do you feel the print quality is very good in color and black.
Any portion of print is missing.
If yes then you change with original new and do the alignment.
