RIM BlackBerry  Pearl  8100 Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to update my bbm on my pearl
I need to update my bbm but when I go to the webpage on my phone to do it through there it says I have to change my Browser ID to Blackberry and I can't. The only two options I have are Internet Brower and t-zones. How can I change the Browser ID to Balckberry?
Anonymous
Level 2:
Scholar:
  • Expert 173 Answers
  • Posted on Nov 19, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
173
Questions
0
Helped
34888
Points
277
To change the home page of the browser complete the following steps:
1) Open the browser.
2) Display the menu, and click Options > Browser Configuration
3) Click the browser to be configured.
4) Change the Start Page option to Home Page.
5) Change the Home Page Address to the web site that should be loaded when the browser is opened.
Note: If the Start Page option is not present, you will be unable to change the home page of that particular browser due to an IT Policy on the BlackBerry smartphone. For more information contact your administrator.
My bbm is not working need someone to sort it out for me
1. update your bbm
2. uninstall it and redownload it
Aug 15, 2014 • Cell Phones
2answers
My samsung phone mega seem not to be getting network, but with full signal showing on it.no bbm, watsapp or mails dropping
If you can make calls and SMS , but not able to log onto the web then it's simple, what you need is to request for internet settings for your model from your SIM card provider. It will be able to access web and all other related apps as you mentioned. Good luck.
1helpful
Why does my bbm say associating bbm with your blackberry id
I rang up today and I fixed my problem, I was told to switch off my phone then take out my battery and sim card. When my phone was back on my bbm was working. I hope this works, as I was dissapointed that mine would not work either. Goodluck !! :)
1helpful
After an update of BBM, I tried to reboot my phone, but never turned on again, just the front led go on red for a seconds.
This has happened to me. Remove the battery for a few seconds, replace the battery, wait for 30secs if it hasnt rebooted by now push the on button. This helped me
My bbm appear , but when i click and add some contacts my credict will deducted but its not working , and my friends does not receieve any request , im using bb pearl flip 8220 . how ?
basically u need to go onto the settings advanced settings then thr router and click the top bit and register it then you have to call say orange if your on orange and tell them that youve regerstird it and they should fix it from there if it doesnt work btw after you do the regerstir bit take out the battery for 10 secs then put back in
I keep getting the bbm icon on my home screen even when i havent recieved a bbm
Hi there lightskin
Your problem is software related, install the software you recieved with your phone, then do a software update via the software, takes about 2/ hours,
* Do not remove your simcard while updating
* Make sure it is fully charged
* Do not recieve or make any calls while updating, (in other words use a simcard of the same service provider which is new and has not been used by any one,
thank you and let us know if there is any other problems
1helpful
I keep getting errors on my Blackberry Curve 8330 that say: java error lack of memory... how can i fix this?
This is usually happened when you install high ram memory application such as BBM 5.
The solution for this problem is by uninstalling your BBM 5. Maybe your BBM 5 has a bug in Java Application. That’s why when you check using diagnostic test in option menu find this warning: UNCAUGHT EXCEPTION: JAVA.LANG.ARRAY INDEX OUT OF BOUNDS EXCEPTION.
After uninstalling BBM 5 you can check now is there any problem again. If yes, the last choice is by reinstalling your Blackberry OS.
1helpful
Can i get cricket service on blackberry pearl?
Sure, a couple of things:
First- you can use BlackBerrys on Cricket in SOME markets. You will NOT be able to use a BlackBerry in an AWS market where Cricket uses the 1900mhz spectrum- simply because the BlackBerry doesn't have that band.
Here is a partial list of AWS markets.
Chicago, IL
Beaumont, TX
Brownsville, TX
Corpus Christi, TX
Laredo, TX
Las Vegas, NV
McAllen, TX
Oklahoma City, OK
St. Louis, MO.
Philadelphia, PA
Milwaukee, WI
Second- the phone doesn't have to be "Unlocked". It needs to be "Flashed".
Third- talk, text, MMS, and internet ARE possible.
Fourth- BlackBerry Internet Services such as BBM and PIN messaging will NOT work. Reason is, you need a BIS account- which Cricket does not provide.
Go to www.bbmedic.com They flash phones.
Using GPS disable all sounds alerts on my phone
You need to go to this webpage: http://na.blackberry.com/eng/support/devices/blackberrypearl8200.jsp
and click on "update your device software on line." You will need your data cable that came with the phone, and a PC with internet connection. install the software onto your PC and follow the directions from there. You could go to your service provider and have them do the updates, but this application is very user friendly. If This does not work, please let me know.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
