As a matter of fact I have a J3816, which is now Homelite... Problem: chain will not cut under load, even light one but the engine will keep running. The chain moves freely (by hand) when engine is stoped; the brake seems to work properly. Thanks a lot for your help.
It sounds as though you have abraded away the clutch face. I’d try a local saw seller/mechanic, they may be able to adhere a new face to your existing parts.
I went here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Chose “38cc 16" Chain Saw UT-10927” and on the “Clutch – Chain Brake – Drive Case Cover” detail found; item 20, clutch, pn984894001, $15.47; item 21, sprocket and drum assembly, pn984640001, $18.46
Yours is an inboard clutch but it must be removed, the outboard clutch video will help.
R² Drive Link Inboard Clutch
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
