If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Testimonial: "thanks"
Depending on how modern your tv is - see if your tv has a VGA input (it looks like a mini scart socket) if so - you can connect your acer laptop vga lead. If you need audio output from your tv aswell you will also need a 3.5 jack extention lead which will also connect directly from your laptop into the tv..
Hope this helps
my t.v has an s-video on the f the laptop does not have one.ront of it
