Ibanez Grg170dxbkn Electric Guitar Hsh Night Logo
yankee c Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to rewire the pickups and the pots on my Ibanez guitar.5 switch 1 vol and 1 tone 3 pickups 2 doub 1 single. thank you much if you can help me yankee c . is my name
  • Anonymous Mar 24, 2014
    I'm trying to find out how to read serial number on my ibanez 170 RG series
    serial number C7127106 can you give me some info on this guitar.thanks [email protected]
Anonymous
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Oct 09, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
62178
Points
212
1helpful
I am trying to wire a Delano 4 conductor pickup with a simple volume and tone control harness wiring into my Ibanez Bass guitar. I am new at this and just getting a buzz when testing.
If you are getting a buzzing sound, the ground connection is wrong. If you google how to wire an electric guitar there is a lot of info on it.
I need the wiring diagram for an Ibanez AS153 semi hollow body, where can I get one?
the 153 is wired like a Les Paul or SG
2 humbucker, 2 vol, 2 tone
with the addition of a 3 way coil tap for the neck pick-up
wired similar to:
http://www.guitarelectronics.com/product/WIRING_MOD_HB0066/Guitar-Wiring-Mod-HumbuckerOFFParallel.html
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
I have an Ibanez s470 and need a wiring diagram for 2humbuckers and 1 singlecoil with a 3 position swicht
What kind of switching options do you want? there are many ways to skin a cat but there are more ways than that to wire a guitar..
Visit the ibanez website for wiring diagrams if it is something simple you want. for more customised switching options,you should contact the pickup brand's customer care...for example,when i bought Dimarzios for my Ibanez,i emailed dimarzio and they replied within 24 hours with a pic of the correct wiring.
Ground wire is not attached
okay. the ground needs to travel through all your components.you have the -input jack, - vol. & tone pots, the -switch & all - pick ups. All should meet at the body ground. Usually there is a wire that comes from the saddle, through the guitar, and enters somewhere in the access in back. (remove the plate that cover your vol. and tone pots). Good Luck
I bought a yamaha electric it has two double pick ups and a single in the middle the volume knob was no good so i changed it when i opened it up they had the wiring all messed up it has a five pos. switch...
my guess is two positions at one end work(aka 1 and 2, or 4 and 5)? if yes, then 2 of the pickups are wired wrong. (if 1 and 2 work, which are the forward positions, then the middle and bridge pickup are wired wrong, etc.) the problem is there is a variety of 5way switches that are different. i would guess yours is "import" style. are there 8 lugs in a single row on the back of the switch? if yes, you probably have an import switch. best i can do in text is tell you that the middle two lugs are common. this means one goes to the volume pot, and there is probably a little jumper between the two lugs as well. now there are 3 lugs on either side of those 2 common lugs. one set of 3 will probably run to the tone pot in some fashion or be empty. the other set of 3 lugs is for the pickup lead wires. it sounds like at least one or two of those lugs are empty but shouldnt be, or are wired wrong. i cant tell you colors of your wires without seeing it, but this is how it should be, with the exception that the tone knob will probably be on the bottom 3 lugs somewhere. 1 would be the neck pickup, 2 the middle, and 3 the bridge hope this helps, feel free to post a pic of your wiring, etc xadioriderx.jpg
Need Fender Squier Bullet 1 w/3 pickups, 1 vol, 1 tone wire diag
I think this is what you are looking for:http://www.squierguitars.com/pdf/current/Strat/Bullet%20Strat%20with%20tremolo-%20Service.pdf Please let me know if this helps.
Top Ibanez Music Experts
Ngoro
john h
Are you an Ibanez Music Expert? Answer questions, earn points and help others
