http://support.asus.com/download/download.aspx?SLanguage=en-us
That is the driver support site. Just choose your laptop, and your operating system. They do not support Windows 7 on your notebook, so just download the xp versions and see if they work.
Hi man First checkout the tuner card audio in put backside of the system one small cable comes along with tuner card it has same pins both sides one side of the pin put in audio out to the tuner card and one side audio in to the system back panel and go to audio controls in the control panel check th line in volume is high or low if line in volume is low u will not get the audio while recording
if you have any doubts give me a msg
i will solve your problem
For every tv tuner card there is line out socket, use two sided phone plug one side of it connect it to the the audio out off tv tuner and another to the Line in socket of your PC,then go the volume properties increase the line in volume. It deffinately solves your problem.If you have any problem regarding this issue leave a feedback,we will glad to assist you
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS 1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot) 2)plug ur spker to line out jack(green slot in computer) 3) double click on small spker icon (left side to ur screen near clock) 4) click options menu>Properties>chose audio out option 4m drop box(see image) 5)click rear pink in >ok And all done have fun
u must connect speaker on tv tuner card;s jack. and go in control panel click on sound and audio device than select audio and change sound playback default device.thanx enjoy good luck plz vote on my comments
I went through the same issue when I bought this unit new. After going round and round, I learned that you MUST use the little dual plug audio wire to put on end into the video card OUT plug (green out line) and the other end into the Audio Card IN (blue in line). That will splice your TV Card into your audio card and sound will miracuosly appear (once you fine tune your audio outputs!). Hope that helps!
