20 Most Recent ASUS VK266H 26 in. LCD TV Questions & Answers
TCL 55X2US. Picture freezing on Netflix ,intermittently, but always from around 4.30..PM
can I help you, sorry it's not android issues. not really why not connect the TV to the router with cat5 Ethernet cable even 100foot (30meters) cables are sold. or move TV to the router locations for 1 simple test. why not tell use if hulu and vudu fail too.? or any of the 10,000 other streaming sources fail.? but first we prove wifi is not the cause, as it is 75% of the time.. next is gee , use PC connected to the router run PC with DRM on and test the Netflix. and see if netlfix works, as it must. for sure Ethernet connected. now my bad story here in USA , I have x16 channel cable modem with 200MB/s speed, (yah fast) wifi fails, easy, if the hood , overloads it easy. so does Ethernet work or not, and what is your wifi distance?, in feet or meters, TV to router, distance, far is slower. If Ethernet works ok, then you solved your problems, in 5 minutes work. (amazing how well wired works no?) lets say a PC works but not the 55" inch tv. that means the Netflix apps fail. I have two 55 inch TV here and 2 blue ray boxes all 4 fail now for netfix. the reason is simple , all 4, have old apps that maker flat refuses to update the ****** APP, so all 4 fail, in very odd ways in fact HULU emailed me and told me my APP is no longer supported, do to major updates with the streaming protocols. in fact all top sites did that. netflix would flat freeze freeze randow or everytime I fast forward. hulu whet flat dead, so all 4 companies failed me. below. LG , TV1 LG, TV2 sony, blueray and Panasonic, " (all 4 said so Solly charley) arrgggggg! the cure in my case, was ROKU. (I use gigalan on mine) paid $100 for mine, and runs the most new APPS forever. not one hiccup ever. (3 years on one) and I run PLEX severs here too, and all that is failure free. recap. just one question, 1st does wired Ethernet fail.?? yes /no???? . a $5 cable. test. most apps if network links are slow? shows buffering, does it?
12/24/2021 7:22:14 PM • ASUS VK266H 26... • Answered on Dec 24, 2021
0answers
Work my web cam on my asus monitor
Go to Asus.com site and download. Link is here: http://usa.asus.com/
Go to "download" section and search for your product via the drop down boxes. Once you find your product, you will be promted to select your current OS. You can then download the correct firmware from here.
Unzip the drivers and run the applicable .exe files as an administrator in Vista.
This should solve your issue;)
4/22/2009 1:26:41 PM • ASUS VK266H 26... • Answered on Apr 22, 2009
Asus transformer/tablets blinking power lights; What do the different colors and combos mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview'/
8/11/2018 3:51:18 AM • ASUS Televison &... • Answered on Aug 11, 2018
Is ASUS CM-16 compatible with verizon fios
That device has the capacity of about 700 Mbs. The fiber cable wont come all the way into your house. There is a point called Dmark that it stops and changes over to conventional wire. That device will work fine.
12/24/2017 2:59:56 AM • ASUS Televison &... • Answered on Dec 24, 2017
Asus vk266H Hi my monitor (ASUS
The backlight driver could be going bad. The ballast control board most likely is the culprit.
10/30/2017 4:44:53 PM • ASUS Televison &... • Answered on Oct 30, 2017
How do I get rid of grid lines on my Asus computer monitor? I have had it less than one year.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD panels are given. You can see and compare to that to your device, and can make sure about the fault to an extent.
10/9/2015 10:57:19 AM • ASUS Televison &... • Answered on Oct 09, 2015
Printer spooler not working google cloud print
https://support.google.com/cloudprint/faq/2541828?hl=en
3/23/2015 8:46:45 PM • ASUS Televison &... • Answered on Mar 23, 2015
Motherboard
pc failure?replace PC
4/18/2012 8:24:07 AM • ASUS Televison &... • Answered on Apr 18, 2012
ASUS VK266H 26 in. LCD TV Logo
8 questions posted
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Televison & Video
Most Popular Question
tcl 55x2us picture freezing netflix
  • Televison & Video
