Hi, I buy the iwave big universal remote control but I lost the codes, do you know where I can find it please... thank you !!!!!
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button. If your TV is not listed use the auto-setup function.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
I came across this technical question on FixYa.com and thought it might interest you:
iwave big universal remote control codes
Check out this question on FixYa - the largest online source for free technical advice on electronics, gadgets and consumer products.
Regards,
FixYa Member phillipcalh
I am not sure if you hae the same one I do, but the way to do a code search if you lose the codes is to pres and hold the device button for a few seconds(tv, vcr, sat, dvd, ect.) it will light up and stay lit, then you press and release the POWER button the light will flash once and stay on. press channel up or channel down and keep doing it untill the device turnes on(I forgot the device has to be off to do this) then when the device turns on you press OK and it stores the code. Hope this helps
Download a manual from Brookstone at: http://www.brookstone.com/bs_assets/files/pdf/product/manual/538744.pdf
What is the codes for a sharp
SOLUTION
I just bought one for my parents. You don't need to know the codes to program it. You can just cycle thru until the remote works. Do this:
1) hold down "CODE SEARCH" button until the LED comes on
2) press&release the device button you want to program e.g. "CABLE", "TV", VCR"...
3) press&release the power button slowly and repeatedly. With each press, the remote advances a code. When your device finally turns on, stop.
4) press&releae the "ENTER" button. You're set.
Note that there are several different codes for most devices. Test all the button functions and if some of them don't work correctly, you might want to repeat the process to see if there is another code that works better.
I got my dvd player to turn on but it wont work after that
I searched for "giant tv remote" and located Brookestone stores. In the brookstone search for "giant tv remote" i located a similar giant remote that appeard to be made by the same company. there was a downloadable pdf manual with all of the brands and codes! Problem solved!
I need a Mitsubishi code
What is the code for Zenith?
What are the nec codes
I have the codes and this thing just does not work
I have the big remote, but cannot find the code for a Motorola cable box (from Verizon). Any suggestions?
i have the big i wave remote and lost the code for it. i have a toshbia TV. any tipsĀ
i just brought THe big Iwave remote and i dont know the codes for A Sharp tv
need directions for large iwave tv remote
i need the codes for a magnavox tv
I bought a iwave giant remote and the codes were not included i have a sharp 36 inch flat screen and i need codes can u help me
i need the codes for my iwave big universal remote. there is no were i can find it on the internet can anybody help me please. ive been searching for ever
Got the iwave super sized tv remote. No codes are listed for a Motorola cable box or a Harmon Kardon surround sound box. Please furnish the codes for me. Thanks for your help
I need the remote control codes for
toshiba tv
I have the iWave big remote and I have lost the codes for our cable box. It is a scientific Atlantic the t.v. is a Samsung 42" LCD. Can you help?
I have a Magnavox cable box with DVR from Comcast. I cannot find the codes for this box in the"Super Sized TV Remote Operation Manual." Where can I get the codes?
I live in Buenos Aires and I bought the iwave big universal remote control. I couldn't find the instructions for programming it and I'm afraid I lost it so I cannot use the control. I would like you to send me the codes for each brand and/or instructions for setting it .Thank you
I also bought the IWAVE big universal remote control and am unable to use it because the instructions and codes were missing. Don
lost the code to my i wave remote
i lost the codes to my iwave big universal remote.
me too.
I have an olevia TV does anyone have the code for that I can't find one in the booklet?
same **** diffrent day
I have an iWave jumbo universal remote. I am trying to configure the remote to a Toshiba television. What do i do?
Hi I also have the iwave big universal remote control and no instructions to connect it to a citizen t.v., please, I would appreciate it if you can pass them on. thanks
I have the iwave big universal remote but i lost the codes
i lost my code book for my i wave super sized remote model rc5000 wat do i do
