HP Photosmart C5180 All-In-One InkJet Printer Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I stop my printer automatically printing out a test page when I switch it on?
mohideen bava
Level 2:
Scholar:
  • HP Expert 199 Answers
  • Posted on Sep 25, 2009
mohideen bava
HP Expert
Level 2:
Scholar:
Answers
199
Questions
Helped
66210
Points
477
Every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 04, 2008
SOURCE: Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Anonymous
  • Posted on May 20, 2008
SOURCE: My printer keeps printing the test page every time it's switched on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
Anonymous
  • 5 Answers
  • Posted on Jul 01, 2008
SOURCE: Prints a test page eac time it switches on!!! how do i turn it off??
try scanning the test page after it prints. this usually stops the printer from reprinting a test page each time it is turned back on.
Anonymous
  • Posted on Dec 28, 2008
SOURCE: Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Anonymous
  • Posted on Sep 18, 2009
SOURCE: My HP PSC 1401 printer always prints the test page
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
My zebra gk420d printer stops printing.
You can ask a printer Maintenance Technician to solve the problem for you.
When printing, it keeps printing the test page first. How can it stop printing the test page??? thx
reset the printer by pressing the reset botton for atleast 5seconds. then it ask for printing the test page.............. and you have to print the test page completely... otherwise it will ask for printing the ttest page at every print......................
then switch off the printer and again on it..........
then you will see th\at the problems will be solved..................
thnx
5helpful
2answers
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
1helpful
Stop printing test page
take test page and scan it this will clear it up
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
I dont want to print test page
as when you get the test page while you on the printer.to stop it.just place the printer side of the test page on the scanner glass.and press the scan button on the printer.the green light will blink for 1 minute.then automatically stop.after that remove the paper from scanner glass.and now you will not get the test page again n again.
Test page
Try shutting down your PC and printer. Next,unplug PC from wall outlet. Next, unplug printer USB cable from the PC, then unplug the USB cable from the printer. Unplug the printer from the wall outlet. Wait 30 seconds. Next, plug PC back into outlet, turn it on, and wait until it has completely initialized and is ready to use. Next, plug in the USB cable from the printer to the PC, and turn on the printer. Windows should automatically detect the printer, and will proceed to install it. After the PC finishes the install, test the printer in all modes, including self-cleaning, to see if the problem is eliminated.
Automatically prints
Print the test page and place it into the scanner, remember to place the paper in the correct direction. Then press the start scan button on the printer. Let the scanner do the scan and if it is successful, the printer is ready for use. If it failed, then the orange led for check paper will flash slowly. If every thing is done in the correct sequence but get failed from time to time, then you may need to get the scanned image of the test page to see what the scanner is seeing.
9helpful
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
