SOURCE: Need CameraMate Windows Vista Driver
I got my CameraMate software to install with Vista but it was a pain in the, well, you know. The install would not clear screens, so I had to manually close screens to get to the prompts hidden underneath to procede. Eventually, it got in there.
Video capture looked good, but no sound. So I thought I'd just route sound to my built in audio. Ok, still nothing. But fiddling with things got it to work, only with an echo. PITA!!
Also, the CamerMate sound DID appear in sound menu. If I enabled it, instant blue screen crash. I didn't think that was possible with Vista. Oh well.
I'm going to rip out the drivers and trash the device. It worked fine under Win2K, except for the speed test on some machines. When I can get a Sabrent PCI capture board for $17, or a full-featured Hauppauge board for $60, why mess with this, when the company won't support it?
SOURCE: frozen mouse with a touch pad laptop computer
Dear MGK7,
That does make it more difficult! Okay, for future reference, when you have key control again and the mouse or touch pad stops working, if you have a standard 101 key keyboard, or even a laptop with one key instead of two on certain keys, you can do it this way:
1. Hit the Windows key, which will open your start menu.
2. Pressing the Windows key and Pause/break will take you to your system properties.
3. Minimizing and restoring screens hit Windows key and "D".
4. To get to Utility Manager, hit Windows key and "U". This will, among other things, allow you to choose to use only the keyboard or the mouse, so you can disconnect the mouse, among many other things.
5. Pressing Windows key and "F1" will take you to Help & Support.
6. Windows key plus "E" takes you to Windows Explorer".
7. Pressing "Cntrl, Alt, Delete" takes you to the task manager.
These keys should provide help in getting around in your system without a mouse.
To get to control panel, for example, press the Windows key to op[en the Start menu, and use the "up arrow" button to go to control panel.
Now that everything appears frozen, power your machine down. Remove the battery from the rear for a few minutes, even if you are operating on A/C plug in. Put the battery back in and power up. Did this make any difference?
You can always buy an inexpensive laptop mouse which works on USB. When you plug in the USB the mouse works independently of everything else. Then you could click the start up memory, help, and choose restore to an earlier time before this problem happened.
That usually will clear any problem.
Please let me know what happens.
Sirwriter
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
SOURCE: C707TU LAPTOP DEVICE DRIVER WIN XP BASED
Download the drivers from the following site http://www.zyxware.com/articles/2007/12/01/drivers/compaq-presario-c707tu-laptop-drivers
Hope this helps
Siju.
SOURCE: targus wireless mouse amw05 does not work, I put
The reciever is poorly designed. The green and/or white wires are probably broken on the inside.(pins 2 and 3)
