My oven isn't working, it was working yesterday, but i had turned it to broil and it didn't come on the top burner. now today the oven isn't working at all but the stove top burners are working, i don;t have an manual for this stove, i was thinking it had something to do with the timer i don't know how to set them, the stove is only 3years old, can you help me?
thanks Nancy Boudreau
If the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
have you set the clock to the right time is that a Kenmore that model number isn't coming up under kenmore on my data base im trying to find you a manuel
and is it a kenmore are you in usa
ok im in tenn usa is that a slide range. i believe that's a Frigidaire serial num for a slide in range .two companies build for kenmore Frigidaire and whirlpool and if you hit bake then 350 should come up in the display and pre heat light should come on if display shows (- - -) then hit temp up and let me know what happens
well first you need to confirm that you have correct power at the out let and where cord connects to the oven if you have proper power coming in then you either have a bad bake switch or thermostat id look at the bake switch first after confirming power,outlet,and cord the thermostat is the dial with all the numbers
i will be here for you just reply will auto e mail me
the clock is lit up, heres the num. mod.# C970-590934, ser.#NF02420987
yes the clock is at the right time, i double checked the mod. # and it is correct.
i'm in New Brunswick, Canada, and it is a Kenmore
when i turned on bake it's a separate dial, just the time of day shows on screen, it turned the other dial to 350o and the light didn't show that the oven was on i tried what u suggested it still didn't work. this stove is just an ordinary one , no selfcleaning, just a dial for Bake, Time Bake, Broil and Off, the other is for the tempertures. then the separate dials for top of stove, which is coils.
i think the temperture switch is not working it feels loose, where the other dial have a click to them, but i removed the dial and manually turned the steel rod, but still the light doesn't come on or the oven, my uncle will be here in a few days to help me move the stove to make sure all the cords are ok, and to see if he can fix it, all these tips you gave me where a lot of help, i'm keeping this info for when he comes, it will help him and i just might have to get in touch with you again, thanks for your help
have 2 electric plugs on top of shacklock stove, don't work anymore
