Hi Fred Tromp, you have two ways to connect the Technics SL PD7 CD player to the Technics SA-DX750
The first is through a fiber optic cable, from the Digital Optical output of the SL-PD7, to Optical Input 1 or Optical Input 2
The other alternative is to use a 2 RCA to 2 RCA cable and connect them between the L and R outputs of the SL-PD7 to the CD L and R inputs on the SA-DX750
I hope you can interconnect the equipment
Regards Franco Dosil
Hola Fred Tromp, tienes dos maneras de conectar el reproductor de CD Technics SL PD7 al Technics SA-DX750
La primera es a traves de un cable de fibra optica, desde la salida Digital Optica del SL-PD7, hasta la Entrada Optica 1 ? Entrada Optica 2
La otra alternativa es usar un cable de 2 RCA a 2 RCA y conectarlos entre las salidas L y R del SL-PD7 a las entradas L y R de CD en el SA-DX750
Espero puedas interconectar los equipos
Saludos Franco Dosil
http://www.usersmanualguide.com/panasonic/compact_disc_changer/sl-pd7
https://www.manualslib.com/manual/169257/Technics-Sa-Dx750.html
SOURCE: How do I conect my ipod to the Technics AV control
You just connect it in the auxilliary input then switch your reciever to auxilliary so you can the sound of your ipod. First buy a wire connector from ipod to reciever.
Hope it may helps;
Regards:
VOTIT
SOURCE: on switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
SOURCE: would like to see the manual on the technics
You can download the complete instruction manual in PDF format by clicking this link.
Thanks for using FixYa.
