I have not lubricated the treadmill.
Could it be from lubricating the walking surface below belt.. see below.
https://www.youtube.com/watch?v=PEvWF7tO0fY
https://www.youtube.com/watch?v=N-G09FIz5g0
manual below
https://www.manualslib.com/products/Gold-S-Gym-Trainer-430i-8879475.html
Testimonial: "I haven't lubricated the treadmill. The owner's manual only says to wipe the dirt and dust off the walking belt. I do see videos on lubricating the walking deck, and I will do that after I figure out where this oil is coming from."
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
SOURCE: I have an E1 error showing on my Roger Black Gold
Your problem might be that a speed sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: cOFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
SOURCE: Cycleops 2 Trainer: trainer is leaking oil...
Crank seal is away. Mine went and i had to strip the fluid2 trainer to replace it. They have a lifetime warranty so they will replace it for you.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
