How to Unjam a Bostitch Stapler
https://homeguides.sfgate.com/how-to-unjam-a-bostitch-stapler-13401638.html
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
SOURCE: I have a jam in Bostich N88RH.
Go here bostich suport page even has a live chat:
http://bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
SOURCE: I can't load staples in a borrowewd SX150 stapler
check the crown size. some are 9/16 others are 1/2
SOURCE: Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
SOURCE: My 20 ga stanley bostich air stapler stopped
Do you have an adj pressure gauge? Take it off, you don't need it for nail guns, Only for painting. Guns run on a full tank, wide open, 120 lbs pressure. If that doesn't set your nail, either the safety is holding you off your work and not letting the staple seat or the gun needs to be rebuilt. Check the drive pin and make sure it didn't break the tip off. Sometimes I wish mine wouldn't set the nails all the way, because some materials, it goes right through. You have to hold it off manually. Also, depending on material, some guns do not have the power to drive into Oak. Only the Senco has the power to do that. we tried every gun made and found it to be the best. Got rid of all the other guns and kept a complete line of Senco guns in our shop. Hope this helps.
