20 Most Recent Fitbit One Activity Tracker, Burgundy Questions & Answers
I had this happen to me. I had purchased this for my eleven year old son. I was putting in his information and ended up getting the Code 541. It turns out that federal law prevents this particular tracker from capturing data for anyone younger than 13. I fudged his birth year and ended up being able to successfully setup my tracker.
Fitbit One... | Answered on Dec 25, 2016
The time on your tracker's display may be incorrect due to the timezone being set incorrectly on your profile, or settings not being synced to your tracker. The time displayed on your tracker is configured using the Fitbit.com website.
You can get detailed instructions on updating the time on the Fitbit.com website.
https://help.fitbit.com/customer/portal/articles/1031792-the-time-is-incorrect-on-my-tracker-s-display
Hope that help!
Fitbit One... | Answered on Jul 29, 2014
It sounded good but made no sense. How do you remove the trigger/ squeeze handle assembly? This thing (Stanley TR70) is riveted together. The only piece that is removable is the staple feed tray.
Tools & Hardware... | Answered 18 hours ago
This belt should be mounted so that the overlap trails when the belt sander is used, sometimes these belts will have arrows indicating the direction of rotation but not always. The arrows usually disappear after a bit of use anyway so if you change grits or re-use belts it is good to know which way to run the belt by looking at the join.
Here another fix that has worked for me. Take some ordinary electricians tape and make several laps around the idler pulley on the belt sander. Put more thicknesses near the center of the idler, than the outside. This effectively builds a small crown on the pulley and makes the belt stay centered. Also, always relieve the tension on the belt when not using the sander. The belt can stretch and tracks poorly if this happens.
Tools & Hardware... | Answered on Jul 17, 2019
Best place is to ask at a Canadian Tire. If you can find the part number on the rotor that would help a lot as you can search for that part specifically online or go to local small motor repair centre for the part or it's equivalent.
I have a brand new one here. It is made by Goodyear. Part number is 150XL037Pd. Made in the USA.
Tools & Hardware... | Answered on Jul 14, 2019
Since Sears does not manufacturer anything, your stapler could be someone else's rebranded. Check for Arrow staples or similar.
Tools & Hardware... | Answered on Jul 11, 2019
Fitbit One Activity Tracker, Burgundy Logo
Popular Tags
16 questions posted
Top Fitbit Tools & Hardware - Others Experts
Marvin
Marvin
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Fitbit Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Fitbit Tools & Hardware - Others
Most Popular Question
purchased fitbit one comes up code 541
  • Tools & Hardware - Others
