Heating & Cooling Logo
Brian Salpeter Posted on Oct 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fireplace glass and surrounding wall felt very hot even though the gas fireplace is off. I turned off the pilot light and it is now cooling. Do I need to also turn off the gas?
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Oct 23, 2019
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567593
Points
3788
If its the type of fire with a constant pilot flame, the top and surrounds will get hot. Obviously, its wasting gas but on some fires, it can be a pain to relight the pilot, hence some People leave the pilot on during the winter season and shut it all down for summer.
5 Related Answers
Shane Hays
  • 82 Answers
  • Posted on Dec 01, 2008
SOURCE: Gas Fireplace pilot light continually goes out
You may have a problem with the flame sensing capillary. It may need to be replaced, or it may need to be positioned into the pilot flame better, or you may need a new gas safety valve. Sometime there is an adjustment screw for the pilot which can make the flame bigger or smaller. If will be on the safety valve.
Frank Bryant Wetzel
  • 456 Answers
  • Posted on Jan 02, 2010
SOURCE: Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
gandolfwzrd
William Lafferty
  • 39 Answers
  • Posted on Jan 03, 2010
SOURCE: I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Anonymous
  • Posted on Jan 05, 2010
SOURCE: gas fireplace won't light up even when pilot light is on
Check for how clean the bottom of the unit is. I know it seems small but when dealing with these amounts of electric current they are just that "small" and the dust can be shorting out the unit and not allowing the gas valve to release the gas. Its a safety thing, they dont want gas around an electrical short "go figure" lol
Anonymous
  • Posted on Jan 17, 2010
SOURCE: Need timer switch for millivolt gas fireplace
These guys are a division of Monessen, a gas fireplace manufacturer, and have a variety of millivolt switches, remotes and thermostats.
http://www.ambienttechnologies.com/
Gas fireplace pilot lights but main burner want turn on.
Thermopile should read 600 millivolts Thermostat has to be millivolts . .
2answers
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 • Dishwashers
2answers
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Switch on wall fireplace with Honeywell control SV9403, pilot does not turn on even there is current flowing into the controller device.
Good Evening. Your fireplace is equipped with a smart valve (SV) to which the valve itself acts as the control. This unit has intermittent pilot or hot surface ignition. Can you clarify to me which ignition this unit has?
How do I turn on my superior ventless fireplace
I'm not sure about that brand, but I finally figured out how to turn the one in the house I just moved into. The only visible control if you have not accessed the fireplace controls before is the switch on the wall. The wall switch is strictly an on off switch, but it only works if the pilot light is already lit, and the pilot light will not go out by turning off the wall switch. To access the controls, first pull out the vent covers, they are simply held in place with pressure buttons on each end. Behind the lower vent are the controls for the pilot light and fire intensity, mine also contained a metal plate with the instructions printed on it. Open the glass door by opening the four latches, two on top and two on bottom, and then swinging it out on its hinge. You will find the gas spout for the pilot light hidden between the logs. Turn on the main gas line by turning the straight edge of the red handle parallel with the gas line. Turn the gas control to pilot, by pushing in and turning, and then push in all the way to start gas flowing. I like to have a match already lit next to the valve when I start the gas. After the pilot light has been on for about 60 seconds let go of the button and it will return to its normal position. Then turn the control to on and turn on the wall switch, the main burners should start lighting. Close the glass and put the vent covers back in place and your ready to enjoy the fireplace :)
1helpful
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Top Heating & Cooling Experts
Paul Carew
john h
