Televison & Video Logo
Nabadwip Posted on Oct 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ic no 8893,what is the ENTIRE no? - Televison & Video
Franco Dosil
Level 3:
Top Expert:
  • Televison & ... Master 10,542 Answers
  • Posted on Oct 13, 2019
Franco Dosil
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379199
Points
178965
Hi Nabadwip, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Nabadwip, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
PHILIPS CTV 5027/94 USED IC 8893CPBNG7B87 RESTART/STAND BY PROBLEM. TV IS OK AFTER IC PIN 64 OPEN.I HAVE CHAKED RESTART CIRCUIT AND CHANGE IC
Hello sir I have the problem in a china kit ic number 8893 tv on standby ,power supply are good but raster problem I found in eht,whit will I do.
2helpful
Can I replace an IC chip on a Hitachi buffer board(part number ND60200-0048) or do I have to replace the entire buffer board?
Replacing the board would be best. You can replace the IC chip but there was a reason the chip burned out. You would need to diagnose the board and find the cause of the short that killed that chip and replace the other parts before you replaced the IC chip. By the time you do this you could have purchased the new board. If you are an experienced repair tech then it may be worth the repair but just for a user then no its not. Ebay has that board available from several sellers for less than $50.
1helpful
How to get replacement parts
Here's their contact info.
VocoPro
1728 Curtiss Court
La Verne, CA 91750
Toll Free: 800-678-5348
TEL: 909-593-8893
FAX: 909-593-8890
I hope this helps you find what you need.
Bobya.
No video output no responce from the on\off button
Resolder entire the video section first where the crt socket is located, look the vertical IC & System control IC for loose pins for solder. Check the ABL for open resistor and fault video ic located at CRT socket.
Where can I find (purchase) replacement antennas for my Vocopro 5805 system
01/10/2013
I just ordered mine for $10 each
from...(called in order)
VocoPro
1728 Curtiss Court
La Verne, CA 91750
TEL: 909-593-8893
1helpful
NO SIGNAL. SCREEN IS LIT WHITE.
Try to check cable connector from main board to controller board, Check entire main board resolder voltage reg. ic, check MCU IC, Scalar IC, EEPROM IC and Crystal Capacitor.
Floor model
If the IC your talking about has a designation number of IC601, the number is MX0841AB-F. Common regulator IC. Sony says that IC is no longer avaialable. You may get lucky and take out the entire G board and have ptscorp.com, or Tristate.com repair the board for you. Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
