20 Most Recent Sony KP-53S65 53" Rear Projection Television Questions & Answers
Does any one have the power board schematics for this TV?
The value of C514 is 390PF 2kv
1/21/2018 1:08:19 AM • Sony KP-53S65... • Answered on Jan 21, 2018
0answers
My power suply board has a green ceramic capacitor the board number is 117736.... exactly what capacitor is it so i can buy 1
What is the location on the board ? Example : C823
6/5/2014 7:41:18 PM • Sony KP-53S65... • Answered on Jun 05, 2014
0answers
TV cannot be turned on
Please count the blinks. It should be a repeating count with a pause. This will indicate the problem circuit and allow us to give you details.
Thanks,
Dan
10/6/2013 3:32:57 PM • Sony KP-53S65... • Answered on Oct 06, 2013
0answers
0answers
I was changing the channel manually and then a circle appeared on the screen and then a bunch of colors, then it went blank. now the standby/timer light is flashing and the tv won't come on.
It probably was a bad product. Call sony and they should send you a replacement depending on how old your product is.
12/17/2012 12:24:56 AM • Sony KP-53S65... • Answered on Dec 17, 2012
Sony kp53s65
A rather older set:picture blinks may be screen controls now set too lowpicture dark same or lens need cleaningcolor off either adjustments or a Convergence issue
3/17/2012 2:40:41 PM • Sony KP-53S65... • Answered on Mar 17, 2012
Sony kp-53s65 no pic has sounds
Trace the voltage to the main board and you must be able to confirm that the +B to the board is in order. since there is sound the front end sections are in order and the fault relates to a failed drive or video process.Check the power to the lamp circuits if there is no output this is the area to trace.if there is glow on the screen then there is absence of video output drive and it needs a trace. use of signal tracing and injection might be needed or you must get help to confirm before any board or costly spare is changed.
11/7/2011 10:50:40 AM • Sony KP-53S65... • Answered on Nov 07, 2011
Burnt out EY34
EY34 is a location near a small blue capacitor that commonly burns up; Location number for the cap should be C514 and the values of it are 1,000 pf (pico farad) at 2 KV (2,000 volt rated).Often if it is burnt it is the only problem and both Hitachi and Sony used the same identical part in several of their sets.Let me know if you have questions.sd tech
9/25/2011 6:37:46 PM • Sony KP-53S65... • Answered on Sep 25, 2011
My sony is on but
mine also does the same so any suggestions would be helpful.
9/13/2011 9:42:59 PM • Sony KP-53S65... • Answered on Sep 13, 2011
Internal voltage regulator
try replacing your lamp and also resenting your timer make sure to get a Philips lamp and if you kneed a ballast try calling discount merchant they are very good and have original lamps also they trouble shoot any problem you may have with your dlp
9/13/2011 9:40:36 PM • Sony KP-53S65... • Answered on Sep 13, 2011
When I turn on the
Does the front light blink any kind of pattern?
8/18/2011 10:30:55 PM • Sony KP-53S65... • Answered on Aug 18, 2011
Tv showing double image and
Sounds like convergence problem. Fixing the problem requires removing, desoldering and soldering the convergence ICs.
The repair for this may go for a couple Hundred or more..
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
7/29/2011 4:42:19 AM • Sony KP-53S65... • Answered on Jul 29, 2011
Where would I purchace these
U must have tools like a soldering iron,a roll of solders,a roll of desoldering braid or a desoldering pump and must have basic skills of doing soldering works?Yes,than tries these 2 websites like Tvrepairworld.com,Tvrepairkits.com to buy a whole tv convergence kit belong to ur tv make and model.The complete convergence kit will came with all and the most common components parts are dying and dead on ur tv make and model in the tv convergence board also with the kit is a tutoring DVD disc.Have no tools and never done soldering work before.Tries this repair at ur own term,after u finish could have complication might not solved ur tv convergence picture problems at all or completely.Or the shop will cost like $300-350 for parts and labors.
7/18/2011 8:05:19 PM • Sony KP-53S65... • Answered on Jul 18, 2011
Sony KP-53S65 53" Rear Projection Television Logo
130 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony rear video projector kp 53s65
  • Televison & Video
