Home Logo
D
David Leitner SR Posted on Oct 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my acorn voyageur wood stove csa approved - Home
Noel Bennett
Level 2:
  • Expert 47 Answers
  • Posted on Oct 11, 2019
Noel Bennett
Expert
Level 2:
Answers
47
Questions
0
Helped
23226
Points
101
There should be a certification plate on the back with a CSA symbol, you may also have a UL symbol it may be equivalent
5 Related Answers
Anonymous
  • 10515 Answers
  • Posted on Aug 28, 2010
SOURCE: I live in Canada and
To be honest with you, there is no way to get round this. In some cases (eg: Ontario), a local hydro inspection prior to purchase, or prior to use, is acceptable. The hydro inspector will affix a "hydro sticker" to the unit, which is as good as CSA approval. But it costs money - last I knew, $75 per unit inspected.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Anonymous
  • 42 Answers
  • Posted on Mar 10, 2011
SOURCE: No problem with unit. Is this air conditioner CSA
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Anonymous
  • Posted on Dec 11, 2011
SOURCE: i need the wall clearances
I need the same! Did you ever find them?
Jamie D
joseph_pr655
Jojo
  • 478 Answers
  • Posted on Oct 02, 2018
SOURCE: I need help to properly arrange or orientate the 12 fire brick back into an Acorn Ranger wood stove that I purchased. The 12 bricks and two short medal bars had been removed to lighten the load.
it's fit to the footing of the stove you should put that 2 there.
john h
  • 29494 Answers
  • Posted on Oct 03, 2018
SOURCE: Does anyone know who manufactures the ACORN RANGER wood stove? I need a manual. A web site would be helpful.
the link has contact numbers Acorn Stove Company Hand Built Custom Coal Wood Burning Stoves
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 • Home
No problem with unit. Is this air conditioner CSA or OSHA approved ?
I need the wall clearances for a voyager acorn wood stove
Jamie D
1helpful
I guess the # is LR3730, or 154ST24898, no other #'s. Need to know how to set it. This is the timer designed to handle CFL's
LR3730 is CSA certification number.
http://directories.csa-international.org/
I don't recognize 154ST number
More information is needed.
Start at link below to help identify timer.
Page shows links to 8 different brands with identifying photos.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment with additional information
I have extensive files on timers
Is there a manual for an Acorn ranger wood stove
I haven't found one.... What i did was put a paint-marker line on the closed position.. Get a decent fire going with the door cracked open about 1" (5-10 min) - set both dampers to 1 full-turn open and close the door. Once it starts kicking heat (another 5 to 10 min) reduce it to 1/8 to 1/4 turn open. Seems to burn great like this. I use mine in the shop so i'll also thrown green and punky wood that I won't burn in my house in the belly of this beast and load it up at the end of the day and then close it down completely. It will burn the green / punk wood all night and will still have lots of coals after 12 hours.
1helpful
About 4 years ago I had a LAARS MAX boiler installed with a Beckett burner and a Superstor water heater. All works well - except minor problem with burner needing to be reset occasionally. BUT when I...
First off they are not suppose to be installing a boiler that is not CSA approved. Your best bet is to contact Laars find out the real truth. I do know Laars was bought out by another company a few years ago, but the Installation company needs to stand by their product and be held accountable.
If unit is not request a new boiler or threaten talking to better business bureau Customers have rights. It also can be a liability to them.
Good luck let me know how it turns out
Looking for a user manual for an Acorn Voyager Wood stove
Check the net. Look up the manufacturer. Have model and serial numbeer ready
1helpful
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
