You need the pins that fit the timer model you have. What is the make and model number of your timer?
In the mean time just plug in a lamp and manually turn it on/off.
Following links might contain help for wiring and setting timer
http://waterheatertimer.org/Timer-modules.html
http://waterheatertimer.org/How-to-set-timers.html
SOURCE: Need 3 items
I found replacement parts at westbend.com, which has now taken over back to basics products. You can also download the owners manual by clicking on the TEM500 and has a download for the owners manual. Hopefully this helps
SOURCE: INstruction manual needed Intermatic HB800RCL
To download the file you need Acrobat reader 7 at least. I just tried it and I was able to get it. It was slow but got it. Go for it and hop this was helpful!
SOURCE: Need to purchase pins to place in the small daily timer of the ti
go to intermatic site
www.intermatic an search for irrigation timers. scroll to bottom of page and you'll see whats listed below
* Includes rain sensor input terminals- rain sensor not supplied.
** Includes 24 volt - 20 VA transformer.
For additional trippers (12 per pack), order No. 156T1950A.
For additional skipper pins (14 per pack), order No. 156T1954A.
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
SOURCE: intermatic Time All ,model TB111. lost plastic pin
I have the pieces for an Intermatic Time All, model TB111 because mine stopped working. I don't know how to get in touch with you.
