20 Most Recent Intermatic Inc. ST01C Digital In-Wall Timer Questions & Answers
2answers
How to set utilitech wall timer for dusk/dawn
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
4/22/2022 3:05:47 AM • Intermatic Inc.... • Answered on Apr 22, 2022
My timer has the lights
If lights are blinking with Intermatic EJ500 or ST01C, then you have the red and blue wires reversed. The red wire should be capped off. The blue wire goes to Load wire.
5/28/2020 1:54:36 PM • Intermatic Inc.... • Answered on May 28, 2020
Utilitech self adjusting wall timer used in place
Your INTERMATIC ST01C Digital In-Wall Timer is not compatible with a REGULAR three-way switch configuration... ((besides being a rather poor timer ( my opinion ))). Following WIRE colors is TOTALLY INCORRECT... (and dangerous). The only way you can "use" this switch is to OVER-RIDE both 3 way switches... BUT YOU SERIOUSLY NEED to KNOW WHAT you are doing...!! I would seriously recommend you consider "SMART" switches... Check out home automation or SMART-HOME ... Insteon... X10 or even LEVITON's remote capable switches... Each end of a "3-way" circuit work closely together... are HARD-WIRED and CANNOT be easily, conveniently or safely overridden (in my opinion). Hope this helps... Naaah... Intermatic KM2STU 1G 1 Gang SPDT 24 Hour Mechanical Timer Amazon com Nope...!! Intermatic ST01 Series Easy Setting Manual Programming Fixed Time One (apple) possibility (ALEXA enabled devices) Eve Light Switch Connected Wall Switch with Apple HomeKit technology for... Another remote (X10 technology (less proprietary & ALEXA compatible)) https://www.amazon.com/s/ref=nb_sb_ss_i_3_11?url=search-alias%3Dtools&field-keywords=insteon+hub+pro+homekit&sprefix=insteon+hub%2Ctools%2C276&crid=3QBCXIC1GUTKD&rh=n%3A228013%2Ck%3Ainsteon+hub+pro+homekit Hope this inspires... Carnac the Magnificent
5/28/2018 7:57:53 AM • Intermatic Inc.... • Answered on May 28, 2018
5answers
I have a utilitech 0192773 self adjusting timer
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
3/13/2017 3:10:33 PM • Intermatic Inc.... • Answered on Mar 13, 2017
I am replacing an old SS5 timer with this new one
Open following link to see clear drawing and instructions for wiring ST01C timer.
Page also has EZ programming steps:
http://waterheatertimer.org/ST01C-program.html#ST01C
Red wire is capped.
Blue wire goes to Load (wire to sconces)
Black wire connects to Line wire (wire from breaker)
Green wire goes to ground.
If you are uncertain about Load and Line wires, just connect them either way, turn power ON, push on-off button, it lights don't come on, then reverse wires.
I have tested this timer, and information here is correct.
Don't forget to install CR2 battery, otherwise display will not show.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
3/31/2016 2:51:14 AM • Intermatic Inc.... • Answered on Mar 31, 2016
HOW TO PROGRAM UTILITECH TIMER MODEL TM-074
The programming does not work on my model TM 74 so I will be returning it to Lowe's.
12/13/2014 8:13:46 PM • Intermatic Inc.... • Answered on Dec 13, 2014
Intermatic light timer stopped working..it has black and blue and red wires my wall box ha 2 black wires
Replace CR2 battery, then reset timer. If functionality is not restored, then replace timer: http://waterheatertimer.org/ST01C-program.html#battery Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 11:19:37 PM • Intermatic Inc.... • Answered on Aug 12, 2014
How do i program
http://waterheatertimer.org/ST01C-program.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 9:35:28 PM • Intermatic Inc.... • Answered on Aug 12, 2014
How install battery in intermatic st01 wall timer?
http://waterheatertimer.org/ST01C-program.html#battery CR2 battery Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/12/2014 9:26:17 PM • Intermatic Inc.... • Answered on Aug 12, 2014
My electronic timer will not switch on automaticlly anymore
Mine sometimes switches itself (!) From AUTO or PGM to SETUP. Simply use your fingernail to open top of door/switch and touch "Mode" button until it reads PGM or AUTO or MAN, as you wish.
7/31/2014 7:05:40 PM • Intermatic Inc.... • Answered on Jul 31, 2014
Intel self adjusting in-wall timer
Reset timer by holding down on-off button then press and release small round reset button. Then release on-off button. Display should flash 12:00 This timer uses CR2 battery. If functionality is not restored after new battery and reset, then timer has probably gone bad? http://waterheatertimer.org/ST01C-program.html ST01 timer has 1 year warranty from intermatic.com gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/28/2014 5:44:51 AM • Intermatic Inc.... • Answered on Jul 28, 2014
Intermatic Inc. ST01C Digital In-Wall Timer Logo
334 questions posted
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Hardware & Accessories
Most Popular Question
want replace two regular switches two
  • Hardware & Accessories
