Coffee Makers & Espresso Machines Logo
C
Cathy Larrison Posted on Oct 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Bunn burner does not heat up
The coffee is hot but the burner is not.
john h
Level 3:
Top Expert:
  • Bunn Master 29,494 Answers
  • Posted on Oct 06, 2019
john h
Bunn Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561455
Points
193449
Test element for failure
4 Related Answers
Anonymous
  • 161 Answers
  • Posted on Jul 07, 2008
SOURCE: Bunn UPR warmer too hot
Try connecting two elements in series. See if this keeps it hot enough. (One switch controlling both burners.) See if another brand of burner will fit in the hole. Check to see if the wattage is lower.
Anonymous
  • 125 Answers
  • Posted on Jan 04, 2009
SOURCE: Bunn Coffee maker leaks
Hi, you can go to www.bunnomatic.com, and select for home or commercial units, and get an 800 number to call for service and parts. If they cannot help you a appliance repair shop should be able to get you going, thank you.
Anonymous
  • 131 Answers
  • Posted on Feb 13, 2009
SOURCE: Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Dec 07, 2009
SOURCE: Bunn cwtf15 coffee isn't hot enough
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
My Bunn coffee maker is making weak coffee
Couple of ideas.
Your weak coffee could be due to the machine not getting hot enough, which is usually caused by calcium scale buildup on the heating element (the "burner").
Try descaling with a citric-acid based cleaner, such as Dezcal or Durgol.
The second is the coffee your using is a weak blend. Try changing to a different coffee and see if the strength is better.
The top burner on our bunn coffee maker is getting to hot, causing the coffee to pop, do you have any suggestions on how to fix this problem? Please advise
Bunn makes a spacer that goes on top of the burner to put space between the burner and the coffee pot, or you can make your own out of a coat hanger. The only other way to fix this is to replace the warmer plate.
Warmer gets to hot over heats coffee
Your coil may be shorting out on your warmer.
Try using the upper warmer and see if the same thing happens. If not, a cheap solution is to swap burners and order a new one . If both overheat, you have too much voltage going to your bunn.
Bunn Dual Wamer not keeping coffee warm
its still under warranty. take it back for a replacement, or send it to bunn, and they will send you a new one
Dec 01, 2008 • Bunn Dual
1helpful
Bunn VPS 3
Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
Dripping
Is the burner hot when this occurs?
Bunn coffee maker
Is the burner hot while your pouring water in?
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
