Drills Logo
M
Meade G Pratali Posted on Oct 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Shopmate 3/8 drill press mod 2620T2. I cant't find the base clamp at home or on line. Any suggestions?
Tom Chichester
Level 3:
Top Expert:
  • Drills Master 62,329 Answers
  • Posted on Apr 27, 2021
Tom Chichester
Drills Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672623
Points
975369
Contact Shopmate or its distributor directly to inquire.
2 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Mar 15, 2009
SOURCE: broken shaft 3/8 milwaukee hammer drill mod #5392-1
Yes it does. The collar mechanism and retaining ring come off and under all that is a sleeve with steel ball bearings, what I am saying is it would be better to take to a repair shop. I worked on this tool for years and they are decent to use, but repairing that without proper equiptment is not fun. Let me know your area and I will try and find a repair center for you.
Anonymous
  • Posted on Dec 27, 2010
SOURCE: Bought a craftsman drill press mod. 11321370 and
try managemylife.com
How do I use drill press stand for drill?
If you want to make a drill press stand for drill and know further about its usage and abilities, you can look at the instructions given below:
  • You can keep an adjustable guide for your drill press to disassemble it whenever you want. Block the guide with two carriage bolts to secure its position and prevent from turning when tightening the knob.
  • A screw is used to attach or remove the adjustable guide. You can use four bolts to hold the drill to the base which is made of MDF. It is very much essential to ensure that drill press stays stable in its place.
  • A table made with HPL panel can be perfect for your stand. It is also called Trespa which is a compact board and strongly built with resins and wood fibers. Plywood can also be considered in this case.
  • Then you have to adjust the height and depth of the drill, make sure that the bit touches the piece and reset the knob to 0.
  • Take a definite depth based on your requirement and lock it to work with it afterward.
  • To make the drill, adjust the guide and then make it.
  • If you are willing to make a deeper drill, you have to use two clamps for that. Two clamps are used to hold the piece to the guide. This lets you drill mostly and safely.
  • The sanding is not all; the drill press can be a thickness planner too.
Source: Things You Need to Know About Drill Press Stand for Drill
More details Best Drill Press For DIY Professionals In 2018
Apr 16, 2018 • Drills
I can't seem to get the chuck open to get the bit out
IF YOU HAVE A GOOD BENCH VISE SET THE BIT OR drill in the bench vice so that the tool and chuck is near against the vice with a small space between the clamps of the chuck and the 2 clamps of the benchvice. place a crowbar between the little space between the 3 clamps of the chuck and the clamps of the benchvice , before doing something spray some wd40 inside the clamps of the chuckwhere the drill is in or bit or whatever. and try to pull off the powertool from the bit of drill if its hard to do then also possible use with a plastic hammer against a light benchhammer where the point is on the clamps of the chuck and on every of the 3 clamps Partly, you can beat in turn 3 times on every clamp down the machine from the drill or bit
Aug 24, 2017 • Drills
How can i get in to my computer as the password is foprgotten and i cannot reset the the password without a disc???
If u forget login to windows password, try this:
1. reset PC
2. Fast press F8 (safe mod)
3. Enter Safe mod option
4. Go on settings-profiles and delete all profiles (only admin u cant delete)
5. Reset PC and login without password
1helpful
McGraw-Edison drill press 2620t2 power switch won't change to on. Is there a safety on the switch that will allow it to function?
if it is a round red button, twist it and pull out
because of safety reasons much of machinery now has this type of control switch so that in an emergency the button is pressed and the machine stops and it stays locked off
Nov 15, 2015 • Drills
1helpful
Operating tips for a drill press
the drill press shaft has a taper in the end and a slot in the side The chuck you will use will have a taper in the back and the adaptor will be tapered to fit in the shaft. The slot is to put in a tapered drift to remove the chuck assembly so that larger drills with tapered shanks can be used. Most twist drills stop at 1/2 inch but reduced shank drills are available with 1/2 ''shank but a bit size up to say 3/4'' After that you will need taper shank drills.. If the drill shaft has a hole from top to bottom you can use special router bits that allow for ma threaded rod to hold them in during milling otherwise the chuck will vibrate and come loose and fall out. It is essential to select the right speed for the drill size being used and I have found that by using combination vices that allow the job to be moved in - out and side ways the jobs you can do are limited by your imagination
Jul 08, 2013 • Drills
2helpful
I have 3 sears 18v battery chargers and they have
re batery got a problem not the charger
Jan 20, 2010 • Drills
2helpful
Best way to attach drill press base to cement floor ? 3/4hp. ITS.
The slots are there so you can use them to clamp work down to the base such as long objects that you need to drill into the end of. There should be holes around the outside, usually in the 4 corners that are there for bolting the base to the floor using expandable anchors in concrete. hope this helps you, Jeepfxr
Drill Presses Installation
Here are a few instructions to follow while installing a Drill Press: Fix the column support to the base using the three screws provided. Slide the table clamp onto the column and align the table with the base and secure it in position using the table clamp lock. Place the head assembly onto the column and slide it down the column as far as possible. Align the head with the table and base and tighten the head locking grub screws with the hex key. Fit the depth scale. Attach the feed wheel. Secure the feed wheel in place with the cap screw using the hex key. Fit the chuck safety shield over the collar of the spindle nose and tighten the clamp screw. Carefully clean out the tapered hole in the chuck and the spindle taper using a clean cloth. Hinge up the shield. Push the chuck onto the spindle and lightly tap the chuck with a piece of wood to ensure proper fitting.
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
