Televison & Video Logo
o
ogunlade olusegun Posted on Sep 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 32inches LG CS410 TV cannot play video from USB hard-drive.
Y 32inches LG CS410 TV cannot play video from USB hard-drive.
Herb Box
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 117 Answers
  • Posted on Sep 30, 2019
Herb Box
Expert
Level 2:
Filmmaker:
Answers
117
Questions
0
Helped
59512
Points
361
Maybe the video format on the USB is not compatible or supported by your LG TV. Look at you user manual for video formats that are playable via USB on your LG TV. If the video format is not supported you can use a video converter to convert it to one that it supports. You can use Free Video Converter by Freemake to convert your video.
5 Related Answers
Anonymous
  • Posted on Feb 26, 2009
SOURCE: DVD player is not able to detect WD 320 GB hard drive
Try reformating the drive with FAT32 file system (this is the default facotry mode).
Thanks,
Siva Kaza
Anonymous
  • 603 Answers
  • Posted on Jan 07, 2010
SOURCE: Can I Connect a USB external hard drive to my LG LCD TV
No TV I know of can do that.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 09, 2010
SOURCE: video playback for toshiba 52xv645u
You can get some external HD Players that have TV out, but quality is not good. Can't you use a laptop with a Video out, or a USB Video Out? Or some DVD players have a USB port, I picked one up the other day for NZ25.00, It plays ALL DVD's and has a USB, so I can play movies from there. Solution or what?
Anonymous
  • 4889 Answers
  • Posted on Mar 28, 2011
SOURCE: i can not play
What happens when you try to play it? Did you try accessing the USB drive through input and then select Movies? Note that cetain formats such as 3GP will not play. The video file needs to be in AVI or MPEG based formats for the tv to play it.
Anonymous
  • 6771 Answers
  • Posted on Apr 22, 2012
SOURCE: can i attach an external usb hard drive to a toshiba lcd tv
The usb external hard drive was designed to work with windows operational system giving access to all the files, attaching the hardware would give limited use at best and may not respond.
My Bush TV has stopped opening USB sticks.
  1. Connect a USB storage device to your TV.
  2. If media is present on the USB device, the Media Browser will automatically load.
  3. Press OK to view available videos on the USB device.
  4. Scroll to a video and press OK to start it playing.
  5. The video will now play.
https://g.page/r/CaGTqqJEio7XEAE
What type of usb do I need to pause. play and record on my 43 in LG smart tv
If this is US model then you can't do recording. Only European TVs allow to record to hard drive or memory stick but not every model.
HOW DO I USE THE USB PORT TO PLAY MOVIES
Some TV models have a USB port so that users could play videos and movies from USB on TV. You can try the following steps:
1. Connect your readable and writable USB drive to computer
2. Copy your movies to USB drive and then disconnect your USB drive from computer.
3. Connect the USB device to the Sony TV USB port. Turn on the connected USB device if necessary.
4. Press the HOME button on Sony remote controller to open the menu.
5. Enter the target USD drive.
6. Select the file you want to play back, and then press the play button to start playing movies on TV via USB drive.
It's quite easy to play movies from USB on smart TV devices.
1helpful
I have an external Toshiba hard drive 3tb. USB 3.0&2.0 There are movies on it( which play on Mac), but the lg smart TV will not show them. The tv recognised the device. Any ideas
The TV will not play Mac formatted files. You will have to play the files thought the Mac that would be connected to the TV as a source. It's a smart TV but not that smart....
Will the Samsung UE27D5000NW LED TV play video from external hard drive?
"Wondering if an external hard drive will draw too much power/amps thru the TV's USB."
Yes, it probably would, so you are better off using a self-powered (one that you plug in to a wall outlet) drive.
And even if you got it running, it might crash halfway through a movie or something. But, for sheets & giggles, if you have all of the data that is on the 2.5" backed up somewhere else, give the 2.5" a try.
Good luck.
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
I have a LG HXF1 but I am not now able to watch my videos any more. It's working, I can see the menu and the setting screen on my TV and the video review. But when I press play the screen goes
Jose Castillo bringing alive posts from 2011 writes
Oct 31, 2022
If you have the factory driver disk I would suggest you reinstall it. They may have been corrupted. Another is that the format cannot be played by the device. According to the information I found on the net, it only plays MPEG.1, 2 and 4 formats only.
Here is information from LG and others
https://www.google.com/search?q=LG+HXF1
1helpful
I can not play the video on my lg tv from usb or rgb pc
My LG BD530 Blue Ray dvd player /usb will accept my 16GB flash drive to view movies as it has a usb plug in. It will not let me play the same movies from my Western Digital 750GB external hard drive. When...
Could very well be that the external hard drive is drawing more power than what the player can deliver - it is enough for a usb stick but not for the external drive. Now if you use an external drive that is self powered I am sure there will be no issue.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
