SOURCE: fan blades rub on housing
The fan is not level.
You will have to relevel the fan. One "trick" we use until a fan can be releveled is to stick a wieght on the top side of the blade. You will have to find which blade will weight back to level. Usually the one on the oposite side of the one that rubs. Tape some quarters or fishing weights on the top side and keep adding until it quits.
Once you get a chance to relevel it get yourself a foot long level and loosen the connections and redo the mountings.
SOURCE: making a knocking noise
This is most likely either a piston noise or a connecting rod bearing knock
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
SOURCE: Dell Inspiron 1200 Fan Making a Noise
Sounds like the fan sucked in some debris.Try looking in with a flashlight.Be sure to unplug the laptop before you try to remove anything you might find.
SOURCE: heater fan makes a noise when i turn it on
Sounds like some leaves or debris may have made its way into your heater fan. heater fan assembly is under the passenger side dash in behind the glove box. You can get at it (or at least see it) by looking up in behind the dash while lying on your back, but this is difficult working position. Easier on back & arms if you remove lower dash section.
The best way to keep your pedal boat is to move your boat into a garage after you use it. You can also keep it on the shore but make sure it is covered. Remember that if you have a plastic boat, water can get in between the hull and the deck. You should make sure that you get the water out before it creates mold.
