If you are using the DirecTV remote, it is possible because it is a universal remote.
Here is a link that will walk you through set up.
https://www.cabletv.com/blog/how-to-program-directv-remote
SOURCE: Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
SOURCE: Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
SOURCE: my tevion universal 8 in 1 remote won't work any tevion devices
tevion is made by konka, try using konka tv settings.
SOURCE: having trouble setting up dvd/vcr
Slide down the cover on remote control.On the bottom right side you'll see a little switch(usually is cowered with the warning white little sticker).Slide that switch to DVD1(or DVD2 if somebody got different setting).Power up DVD/VCR combo press system menu botton,go to settings,change to DVD3(factory default)and there you go.Good luck.
Rich
SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD
Player Combo press DVD/VCR once. After programming a VCR Combo device,
you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a
DVD Combo device, you will be able to control channel selection, volume, and
DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and
then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 to 5, trying each code for your
brand until you find one that works. If it still doesn't work, try Searching
For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when
the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are
searching for.
Thank You
