SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
SOURCE: my yamaha 1100 waverunner will not turn on . I
u need to push mode and hold it it will display ---- push aaaa that is the factory start code for that year if that dosent work let me know and we will have to find out what code you need if aaaa works after u push the code it should say start
SOURCE: yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
SOURCE: I have a 2000 Yamaha XL1200 waverunner. When I
my 1998 xl 1200 has this thing it the batter is changed or if it sits for awhile you have to hit mode then something that says code should pop up on the screen then hit a b c a and then it should be able to start. but your code may be different
SOURCE: how do I reset the code on a yamaha waverunner
How do I reset the code on dash board 99 yamaha waverunner 800?
