Hi I've just replaced the back and front housing of my w910i. All seemed to be well (I've done this sucessfully before and I know to be careful) but now I'm unable to make or receive calls.
Antennae are all present and connected - the phone is unlocked and I've tried both an O2 and 3 sim. They both detect the network straight away with a decent signal (both sims work fine in other phones).
One thing that does happen is that the connection disappears occasionally.
It is possible that the housing for the water pump has corroded and the new(hopefully) gasket is unable to seal off properly. Water pumps have a bleed hole underneath before the bearing so that in the event of the seal leaking the water will run out and not affect the bearing. May be the housing was not cleaned properly and a piece of old gasket is preventing the new gasket for fitting properly. If you have doubts that he did the job go back and front him to get the job done properly. Remember that in future the replaced part is yours and you have rights in law to take the old part home with you to prove it was changed.
Hi, first for the pictures captured to be saved, might be that your phone memory if full and no other place for it to save the pictures.if you have an external memory card, change the storage device to save to memory card in your camera settings.
And secondly, if you want the call logged call registry to display, you will have to copy the numbers into the phone memory before the call logg can display callers identity.
1.backup first all of your contacts and important files 2.make a master clear w/ your phone and after restart. 3.if still the same make a fullflash or upgrade your firmware.
