SOURCE: nokia 6600 phone unlock codes
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file named .mdl and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code
file will be @site www.MegaShare.com/218723..just select free download..tats it u r done
SOURCE: Hello Sir, can plz help me with the format code
Dear use *#7370# to do soft reset and this will reset your phone.
SOURCE: plz tell me how i unlock the lock code plz i forgot my password
please post your imei number and i calculate your lock code right now..thanks
SOURCE: hello sir my nokia 2690
Set back to factory default settings ,if you look in your manual for your phone it should tell you what the default code is if your requires one.
Failing this you need to go on the internet on the Nokia website and place ........................
............factory default setting codes for Nokia 2690, you will also need to remove your phones battery and write down the serial number and any code numbers for your phone that are on the reverse of your phone not your battery. before you go on the internet.
Steve B
