20 Most Recent
Nokia 7210 Questions & Answers
I'm forget my 7210 supernova
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
Reset factory setting with nokia flasher box.
Thanks
4/19/2018 11:34:40 AM •
Nokia 7210
Answered
on Apr 19, 2018
Mobile softwear virus attack. mobile virus scaning
This is a guide how to reset your phone to factory setting eliminating all problems/viruses.
C.O.D.E 1: --->>*#7370#
C.O.D.E 2: --->>
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button, press-> 3, press-> *,
STEP: 3. Now Switch on your Mobile.
10/31/2016 6:16:17 AM •
Nokia 7210
Answered
on Oct 31, 2016
Lost phone
When was the last time you had it? what carrier you on, make sure you tell them its lost and them your imei number which will be found on the box, this helps as if anyone has got your phone its will be blacklisted and no one will be able to use it, problem is if the phone is in your mum or dads name they might be the only one who is able to claim the phone as lost. Good Luck, i would recomend you telling your parents though, sooner the better
10/21/2016 4:27:26 AM •
Nokia 7210
Answered
on Oct 21, 2016
My nokia7210 displayed "not enough memory" while
hi! nothing to worry! follow these steps to solve ur issue!
1. more applications run in ur phone may cause ur phone wont play music!
2. uninstall all ur unwanted programs that jam ur phone memory ant try to install all it in ur memory card if possible!
3.then open ur phone file manager clear all unwanted items in ur phone memory! make it free as much as possible!
4. restart ur phone by switch off and switch on ur phone! then play songs! Enjoy music!
That's it! ur problem solved! Rate or comment me if u like my solution!
6/25/2015 6:19:41 AM •
Nokia 7210
Answered
on Jun 25, 2015
My nokia7210 supernova does not
Welcome to FixYa!
To have more storage capacity for your phone, delete unimportant SMS in your INBOX, OUTBOX and SENT ITEMS. Delete also unimportant pictures, videos, music and ringtones. The phone memory is relatively small and is shared to all data and other files that are stored in the phone. By deleting some of these will free you some memory.
Alternatively, you can also put in a Micro SD memory card(Memory Card model depends to what your cell phone is compatible of, Micro SD is a sample) to your phone which will also increase its storage capacity. A Micro SD Card look something like the picture below.
A 16GB Micro SD is available at AMAZON http://astore.amazon.com/doityousol-20/detail/B001L1H0SC
Thank you for using FixYa.
Have a great day.
Jas247
6/25/2015 6:18:45 AM •
Nokia 7210
Answered
on Jun 25, 2015
When I go music player
It shows that the memory level of your memory card is full so either you delete some infroamtions there or go for a bigger memory like 8GB
6/25/2015 6:15:34 AM •
Nokia 7210
Answered
on Jun 25, 2015
How to flash my nokia
your phone memory is about to full.you should move some items from phone memory to memory card untill this problem presist.after this updating library automatically started.after updating your music player work.
12/26/2014 10:12:56 AM •
Nokia 7210
Answered
on Dec 26, 2014
