SanDisk Sansa e260 MP3 Player Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to operate sansa and creating data base - SanDisk Sansa e260 MP3 Player
YourZEN
Level 3:
  • Master 820 Answers
  • Posted on Sep 13, 2009
YourZEN
Master
Level 3:
Answers
820
Questions
0
Helped
370993
Points
2866
Sansa support for e200 series:
http://www.sansa.com/support/sansa_e200/faqs
user manual e200
For making videos appropriate for your player use:
sansa media converter
When a total reinstall for the player is required perform:
sansa firmware updater
Remember: running a firmware update will erase all data on the player !
For transferring files from the computer towards the player you can use
Windows Media Player 11. A short guide in how to make transfers:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
I have sansa sandisk reburb 2GB mp3 player, it shows refresh data base, please tell me about the action, thanks, bharat
That action happens when you add more files in it! At the first time after you have inserted new files, the player will be checking and creating the list of the files it has inside! Depending on how much data you have changed/added, this process can take up to 10 minutes!
Lost the cd that came with this model
Support on the cd is a manual and a firmware updater.
A manual for the Sansa View in pdf format, readable with Adobe Reader, can be reached with next link:
http://mp3support.sandisk.com/sansa/UserManual/VIEW/View_UM_English.pdf
For Windows based operating systems a download for the Sansa Firmware Updater
can be obtained, following the steps as described on next site:
http://kb.sandisk.com/app/answers/detail/a_id/304
For Mac and Linux based operating systems go for help links to the Sansa Forums site:
http://forums.sandisk.com/sansa/board?board.id=view
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sansa freezes
try inserting a microSD card when player is turned off then put it on...work most of the times...
Frozen sansa
Most probably the device's data base needs a reset. Check out this link: Sansa e250 Frozen
How to create database in m.s.office
you can create static data base in Excel works heet and link each cell to another sheet.
or you can create a dynamic data base in access. you need a MS access book. there are lots link you need to understand in order to have a working data base.
2answers
Songs title
my sansa dont work she rait my refreche data base i waite and nating
How to create program in delphi
i wants to create form for data input
with the condition
I some how deletted everything can i get it back ?
you can fix the problem by having the original sansa files when you format it it deletes everything
get a friends sansa files or do this
and just because it would be a pain looking for the original files i uploaded here for people who deleted them put these files into a folder named
DATA http://www.divshare.com/download/4002990-1d7
WMDRMPD http://www.divshare.com/download/4003086-013
REFS--no files
and put them in into 1 folder named SYSTEM--make it hidden then put it on sansa
then create a music folder make it hidden
then create photo folder with thumbnail and my album folder make my album hidden
then create pictures folder make it hidden
then create playlists folder make it hidden put this file in it
http://www.divshare.com/download/4003139-94b
make a record folder with 2 folders named radio and voice
make a folder video
captilize all these except the one listed below
make a tmp folder
this should work :)
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
