LG 24 in. LDS 5811 Built-in Dishwasher Logo
Anonymous Posted on Sep 11, 2009
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
The dishwasher started leaking water and shortly afterwards showed the E1 error.
After receiving the E1 error, I checked the inlet filter and it is clean. No bends in the inlet pipe either and I have good water pressure.
I then unplugged the dishwasher for a couple of hours, and then switched it on again.
It does not come up with the E1 error anymore, but leaks a lot of water now (within 5 minutes). When I open the device, the whole floor section is flooded with water. I cleaned the floor section filters as well, to no avail..same problem.
Thanks for your suggestions.
Otto
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
Answers
725
Questions
Helped
407073
Points
1785
E1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Testimonial: "Thank you. I found the water leak. It was the water heater assembly that leaked the water... replaced it, all is fine now. Thanks for your help."
My LG intello dishwasher LD2050SH gives me an E1 error
AE & E1 ERROR CODE - DISH WASHER
LG Electronics https://www.lg.com > support > help-library > ae-e1-er...
Nov 8, 2023 - An AE or E1 error code means you have a leak inside your dishwasher activating the float switch. Before you can start using your dishwasher ...
Missing: LD2050SH ‎' Show results with: LD2050SH
Help library: AE & E1 error code - Dishwasher
LG Electronics https://www.lg.com > Home > Support > Troubleshoot
Dec 13, 2023 - The AE or E1 error code indicates a possible leak from the unit. ... Then run an empty cycle with nothing in it to clean out the dishwasher. If ...
Missing: intello ‎ LD2050SH
LG Dishwasher - Error Code List ' LG USA Support
LG Electronics https://www.lg.com > support > help-library > lg-dish...
Jun 20, 2023 - If overfilling occurs, the flow switch will trigger an E1 error code and your dishwasher will turn off to prevent outside leakage.
2answers
LG dishwasher LD2080TH Error code: E1
LG has programmed in the E1 error code to indicate when the drain pump is running, it is not receiving the back pressure it needs. This is most likely an indication that there is a water leak in the draining system.
https://removeandreplace.com/2017/03/06/lg-dishwasher-error-code-e1-how-to-clear/
2helpful
LG Model 67LDO210 Error E1
Hi, the "E1" error code means the dishwasher has developed a leak. Meaning your outlet hose is too low or too far down the drain, it is losing water while it is washing making it think there is a leak...
Jan 16, 2011 • Dishwashers
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
1helpful
4helpful
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
3helpful
E1=Water inlet Error
Not reached to the normal
water level in spite
of 10 min. water supply
Causes:
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
2answers
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 • Dishwashers
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
