Heating & Cooling Logo
g
gary Posted on Jul 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Fuji wall unit is blowing 80 on car themetor what should normal temp be out of wall unit
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Jul 23, 2019
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1252014
Points
7008
Should be about 20 degrees cooler than the temp going into machine
4 Related Answers
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Nov 01, 2008
SOURCE: car heater
you did check your coolant level right? Has anything been worked on as far as cooling system lately? Radiator, thermostat, rad cap, antifreeze changed/flushed?
Anonymous
  • 5 Answers
  • Posted on Mar 09, 2009
SOURCE: ford mondeo mk3, intermitent dumping of water from
You may have an air pocket in your system which some times happens.  One way to get rid of it is to take the upper hose off on the engine side,  fill your system with water until it runs out from your engine block, replace the hose, start your car turn you heater on and set to hi keep the radiator cap loose until the temp start to rise then close tight.  Once the air pocket had been remover you can drain some of the water from the radiator using the lower drain plug and add antifreeze.
Anonymous
  • Posted on Feb 20, 2010
SOURCE: heater fan will not blow. car operates at normal
1992 heater / ac fan stays on even if car is off deville?
Anonymous
  • 141 Answers
  • Posted on Nov 21, 2010
SOURCE: 300M WARMS UP TO NORMAL TEMP HEAT BLOWS HOT THEN
this can be 2 problems the thermostat
or the module pcm that controls the digital controls on the dash panel
this is for the ac and the cluster if you change it you need to ask them to write your milles in it
i got one for a town and country and fix the ac problem anf it also give me 80k aditional miles
do the dance key test
you open and close the ignition key 3 times and the cluster will display error codes from the computer
with the codes we can solve this problem
My Fuji ac ductless wall unit is blowing cold measured At 80 I do not think is normal what should it be
Are you saying the cold air coming out of the unit is 80 degrees F? If some, you a right, that is not normal nor what most people would say is cold. Make sure your control shows the unit is set on cool or automatic, If your hand control is set to heat, it will never produce cold air.
Assuming the control unit is in cool or automatic mode and the temperature is set to the room temperature you want, there may be a problem with low freon in the unit caused by a leak. In that case you will need a tech to measure your freon levels and detect and seal the leak. Unless you have the knowledge and correct measuring equipment you will be be able to do that yourself, nor will you have tools to recover freon or a tank of freon, a tank of nitrogen to pressure test, etc.
1helpful
Our upstairs Central AC unit will not cool below 80 degrees. Everything is blowing fine. It is 89 degrees outside today. The air coming in thru the ducts is 80 degrees. The downstairs unit blows 70...
you will need a thermometer, you can use a meat therm.take a temp reading of the air going into the return and then coming out of the supply at the unit, it should be at least 15 to 20 degrees cooler in the supply, if not it may be low on refrigerant also check filter and return duct make sure your not pulling air from attic
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
1helpful
I just bought a samsung 15k BTU window a/c, I haven't seen any water dripping out of the bottom of the unit. In fact there is absolutely no moisture anywhere. Is this normal. Humidity is low, and it is...
If the humidity is low then the amount of water removed will be low. The AC (I assume is a window unit) May be evaporating it off as soon as its drained outside..
Yes in low temps and humidity it is normal for no moisture to be made in abundance.
This is all assuming the temp is coming down as you direct it to.
Please rate me as high as you can and thank you for using fix ya.
I just moved in. What happens when you shut the wall switch off.
If the wall control is the thermostat, then if you shut it off, your unit will not come on at all. If there is a pilot on your heater, it will remain on unless you shut it off at the gasvalve or gas shut off valve. Some heaters light themselves when they need to come on.
2answers
My heater is blowing cold air what can I do?
Hello, The normal operating temp for this car is about 95°C. If your car is not running this temp after it warms up, you probably have a bad thermostat.
If you are not getting good air flow, have someone ck your cabin filter. It could be stopped up bad giving you weak airflow. It is located on the right side at the bottom of the dash.
If you find this information to be correct would you please enter a "fixya" rating.
Thanks, Gator241
Refrigerator noises
your refrig will have "normal" off cycles for when the temp control is satisified and when it goes into defrost cycle. normal run time for most units is 60-80%. main thing though is that your temps are normal. thx peyton
Gauges giving me trouble
Oil pressure sending unit probably bad.
Temp sounds ok.
Freezer runs all the time
I don't have enough information. Use a freezer thermometer and check the temp. If below 0 probably a bad thermostat. Sides getting hot is normal. Thats how it gets rid of the heat from inside. In the summer a freezer can run over 80% of the time. Again this is normal. Another thing to check is the gasket around the door. See if it is worn or torn and is sealing properly. If there are condensor coils under neath clean them check to see if the fan under there is working when compressor is running. (Not all freezers have coils underneath. Some have them in back, Smaller units just use the side of the cabinet.)
Top Heating & Cooling Experts
Paul Carew
john h
