I have just acquired a Panasonic Home Theatre SC-PT450.Which is connected to the TV with an HDMI link and audio cable
Everything is fine in DVD mode but the Surround sound will not function in TV mode.
Any suggestions.
Thanks
Bill
SOURCE: Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
SOURCE: Extension speaker wire
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
SOURCE: cANNOT WATCH iPOD mUSIC vIDEO on Panasonic SC-PT865
Maybe because is only read audio, like Photos and mp3 audio only, expecially if read format llike "High Mat" to read photos and music, try to go to instructions manual and see the format what your dvd read.
SOURCE: cant get my viera linked panasonic to play through surround sound
hi i just bought the panasonic sc-pt460 and had the same problem, i connected it to my 37" LG lcd tellevision but couldnt get no sound from the tv, tried what they said in the manual but no joy , then i came across a scart lead in my cupboard which has two audio jacks and a scart plug on the other end which has a switch on it saying IN/OUT i connected it to av1 on the telly and switched the scart to out. hay presto, and to think i was just about to send it back glad i never what a sound system
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
I am having the same problem as Bill. Again, I have used the HDMI cable to connect directly to the TV, and the surround sound works great when watching a DVD, but doesn't work when watching the TV. I have an LG 32LC56 which I also run a Virgin digital box through. Any ideas would be greatly appreciated as its beginning to drive me and family mad!!!!
