Why wont my sa-ht720 turn on... i have everything
Check first for shorted speaker leads or blown (shorted) speakers.Chances are, that's not the issue though.There's a good chance you have failing electrolytic capacitors in the power section.Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.If you are handy with a soldering iron and can identify the power supply section an inexpensive handful of capacitors will likely fix you right up.Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).Most of the caps that go are 10V 1000uF or 3300uF.I found some great videos of the procedure (for many Samsung flat panels, but the principal is the same) on youtube.http://www.youtube.com/watch?v=Mm51C_RDIZEhttp://www.youtube.com/watch?v=BNHHrgX_6cs&feature=relatedhttp://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwphttp://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=relatedAs you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, and many other electronic products using these components - and it's becoming more and more a rampant issue!The parts are cheap, and skill required is minimal. I order mine from www.digikey.com as they are less than a buck a piece plus shipping, and they usually arrive the next business day.
7/15/2011 9:36:26 PM •
Panasonic...
Answered
on Jul 15, 2011
