I have an HP laptop OS Vista, i have a canoscan 5000f scanner which does not work. i tried to downloading the driver for vista 32bit it does not work. I have a 64 bit. Any help with getting the scanner to work?
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Hello, you need vista 64bit driver, you cant use 32 bit. and when I checked the website, it doesent exist any 64bit drivers. the OS 64bit is not supported. sorry. you cant get your scanner to work with 64bit
This looks good to me from Canon's support pages:
http://tinyurl.com/nq4w42
When you get there, select your OS & proceed from there.
I hope the below link is working for you.
It gives your the cannon driver support page for your scanner model. In the OS pull down menu you can select 64 bit vista drivers.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8053
Hope this helps.
