Is there a way to make a stud wall for a shower part transparent?
You mean clear plastic dry wall? or how about a window? How about removing the wall and putting in glass panel? Glass block? Anything can be done, depends on your imagination. An exterior wall can be totally removed with a lintel replaced in the top, and interior wall can be totally removed with no lintel, depending on trusses, or rafter placement.If you want to leave the studs exposed in the wall, I would clean them up a bit. The problem with that is you can't clean it and the panels are subject to fogging up inside, condensation will get in there, an exterior wall is a bad idea, no insulation. Hope this helps.
