20 Most Recent
ViewSonic N3000W 30 in. HD-Ready LCD Television Questions & Answers
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Remote control
What is the problem with the remote control? Do you wish to buy a new remote control for this TV?
If you wish to buy its original remote control, you have to
contact the authorized service center.
If you wish to buy a universal remote control, you should know about,
which brand remote control have setup code to your TV/device brand. You should
first make sure about the number of digits in the codes to your device
have. There are 3-digit, 4-digit,
5-digit and even 2-digit codes. You can get this detail by the code list
attached to every universal remote control.
The brand name of the remote control you select isn't a matter; but, its
code list should have setup codes to your TV/device brand, otherwise you can't
set it up with your device. Check out,
which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to
some popular brand remote controls are given.
Check it, and determine which brand remote control should be bought, and
buy that brand remote control, according to availability. Check the sites linked here.
Set-up code list, and Set-up procedure to many popular brand remote
controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic
/ Timeslide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a
search, by type in the brand name of your TV / Device, in the search box
at the top right of the display window.
Hi, My viewsonic 3753W is
The guide, says to press VOL+ and Menu at the same time,
a) it's from the TV buttons NOT the remote!!!
b) you need to keep pressing these 2 until it stop saying "Power unlocking" but Unlocked.
Hi.
Only the small swich
can you please rephrase the question by giving detailed information about what went wrong with your TV? I don't really understand the question.
I look forward to your reply.
Bye for now.
Take care.
Standby ?? no Power ?? no Working ??
Gruesse ;-)
Power supply failures are too common in later sets and I suspect that is what you have.
The supply is normally on a separate board and can be replaced by the owner if you can find one to buy.
Remove the back panel of the set and look for a smaller board with larger parts on it that seems closest to the AC (wechselspanning) input.
If you replace it, do not throw the old one away, look for a repair company, the cost shouldn't be more than 75% of the new one and you will likely need to have a spare.
Viel glueck!
Viewsonic N3000w LCD TV randomly shuts off...
It seems that the power fails quite often with this one burning the Inverter boards transformers. OZ960G chip may not be broken, so try getting a new power from somewhere. Measure the transformers. suppose to be somewhat 5 ohms. tolerance is +-1.5 ohm. of more, replace.
Trying to hook up my PS3 to my Viewsonic N3000W to
Your TV has a DVI input connector, but no HDMI as you noted. Adapters (fondly called "dongles") are available to convert from the DVI connector to an HDMI jack so you can connect your HDMI source. Search for "dvi to hdmi adapter" with your favorite search engine and you will find them.
As for settings, this set has 720p resolution. Make sure your source is set accordingly, and you should be set to get the best quality you can with the connections available.
Please take a moment to give this solution a fixya rating if you've found it what you needed, and thanks for asking here!
ViewsSonic n3000w sound working, but picture is not
Your inverter is bad. i think there's 8 transformers.. one for each backlight.. one of them is sorted and is bad.. if you know something about electrics you can try to find one transformer or you can try to find the whole inverter.. good place for parts is http://www.lcdparts.net
How do I remove the base from the lg 50 inch plasma
i have the same problem. maybe if enough of us start bubbling up all over the place we will hit the radar of the dense design team at LG. with luck, we will also get an answer from their support group. c'mon LG, where is your sense of intuitive usability???????
