SOURCE: SAMSUNG REFRIGERATORS
try here my friend http://www.samsung.com/uk/consumer/type/type.do?group=homeappliances&type=refrigerator
SOURCE: find common dimensions of refrigerators, height, width, depth
There's a zillion makes and models of refrigerators with new one's coming on the maket all the time.
There is no standard fridge manufacturers must follow.
When I find a bad machine, and the customer want's to replace with new, I advise them to take the width and height of their opening before shopping, or be willing to remodel.
Best advice I can give you is plan the refrigerator opening for the worse case scenario on all your rentals.
As a general rule, refrigerators are becoming larger, and probably will continue that trend.
SOURCE: What is the cubic feet
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
SOURCE: I need the dimensions of
Hello, click this link for the height, width, and depth http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=982470017.PDF
click this link as well for any further information on the unit that you may require http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=TBX18AABWW
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
SOURCE: inches to cubic feet 11 X 22 X 15 height X Width X Depth
ft³ =in³ * 0.00057870
3630 in³ = 2.1007 ft³
