Does your tstat have a C wire? If yes, take the batteries out and leave them out. The tstat will quickly learn it doesnt need batteries.
Hello, make sure that the connections are clean on either end of which your battery goes, also make sure that you have fresh batteries if you could check the voltage that would be nice and finally make sure that your batteries are in the right polarization If either one or all three of those suggestions do not work I would suggest replacing the whole unit. Good luck
SOURCE: CMOS battery low. I changed the battery but the message keep reapearing
Pull out the battery and clean the contact and try again. It may solve your problem. ([email protected])
SOURCE: system keeps beeping that sensor 3 is low battery
Did you try a system reset? You should be able to bypass.
SOURCE: My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
SOURCE: Screen says bat low
Found the manual online and it said to put the batteries in backwards for at least 5 seconds to re-set the thermostat. Amazingly, this worked.
Testimonial: "cool"
SOURCE: Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
