Motorola Mobility Bluetooth Headset-Silver/Black Headset Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to put motorola bluetooth in pairing mode?
Anonymous
Level 2:
Scholar:
  • Expert 86 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
86
Questions
0
Helped
34653
Points
292
Hi there - follow the step-by-step instructions here:
http://direct.motorola.com/eng/bluetoothselect.asp?country=GBR&am
Just pick your model and it will guide you through it;
4 Related Answers
Anonymous
  • Posted on Jun 04, 2009
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Anonymous
  • 827 Answers
  • Posted on Dec 22, 2008
SOURCE: HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Anonymous
  • Posted on May 24, 2009
SOURCE: pairing Motorola D650 to Motorola S9 with ipod nano or touch
It does work with the itouch. Try turning off the ipod completely. Turn it on again, then plug in the D650 and then your S9. Enjoy!
Anonymous
  • 5 Answers
  • Posted on Feb 12, 2010
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
1helpful
Can't pair up my bluetooth to phone
Consult your bluetooths manual for how to put the device into pairing mode. Once it is in pairing mode search for it in your phones bluetooth menu. Select it, if prompted enter the pin code 0000.
Rylan
How do I change my Motorola bluetooth to my new blackberry
You will have to put your motorola headset to pairing mode usually you have to hold the power button until you see that the light on the constantly on either red or blue. once its in pairing mode then you have to make sure youe bluetooth on the phone is on and then search for bluetooth. the default password on motorola bluetooth are 0000. hope this helps
3helpful
Need instructions on how to pair bluetooth motorola H710 with blackberry curve
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
1helpful
How to conect Motorola H500 Bluetooth Headset to Iphone
21helpful
How do i pair my motorola H390 bluetooth on a katana
1helpful
My LG Voyager cannot find my Motorola Bluetooth H710
How do I add a 2nd phone to motorola bluetooth headset h710?
after you connect one phone. go into phone settings and turn off bluetooth. go to second phone open bluetooth options. not put your h710 into pairing mode. once paired, go back to original phone, turn bluetooth setting back on, and both devices are now paired.
How do i link up my H3 motorola bluetooth to my motorola i776
7helpful
I can't pair my motorola h681 bluetooth and my SGH -A837
2answers
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
