20 Most Recent Motorola Mobility Bluetooth Headset-Silver/Black Headset Questions & Answers
the default wifi passkey is usually printed on the label stuck to the router. you can login to the router using admin admin with a lan cable connected pc start a browser and enter 192.168.1.1 into a browser to get the menu up. you can then alter the wifi passkey value to whatever value you prefer. ALL Wifi signals have a PassKey by default so you must have entered it at some stage to the working devices.
Motorola... | Answered on Oct 18, 2017
Hi David Johnson
The default password that some device required is (0000).
Regards
Marge
Motorola Mobility
Motorola... | Answered on Oct 02, 2014
While bidding on an item the reserve price was lowered putting my max bid above it and good for the win but Ebay manipulated my bid and lowered it to below the new reserve and cost me the item. I complained and they told me it was for my protection they took the item away from me. They did not protect me I wanted the item. This seems to help the buyers who have no intention of buying the item just running the bid up. How can I get this resolved
Motorola... | Answered on Feb 17, 2011
I'm having the exact same problem!
Motorola... | Answered on Feb 07, 2011
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.png User Guide (pdf) - UntitledThe instructions you need start on page 15
Motorola... | Answered on Jan 29, 2011
You can get the pairing for you device on the link below.
http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Good Luck and please rate 4 thumbs up for the free answer
Motorola... | Answered on Oct 01, 2010
The passkey is 0000 (four zeros)
For more details, download and refer to the manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa.
Motorola... | Answered on Sep 20, 2010
ok, this is a bit complicated of a matter so ill make it as simple as possible. First of all, the first generation iPod Touches DO NOT have bluetooth capability, so if your ipod is a first generation you cant use bluetooth. Second, the iPod must be running on the latest firmware, which can be updated through iTunes. Third, iPod Touches CANNOT pair with bluetooth headsets (such as the ones you use with a cell phone the go over one ear) however they CAN be paired with bluetooth HEADPHONES (go over your entire head to cover both ears) now assuming you meet the above criteria, the option for bluetooth is in Settings>General>Bluetooth On. place the device in pairing mode and it should be discovered. if it is not, you are using an incompatible Bluetooth Device. Hope This Helped! Remember to Rate
Motorola... | Answered on Aug 26, 2010
The numeric passkey is 0000 (four zeroes)
For more details, download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Motorola... | Answered on Aug 10, 2010
they control the volume and the call waiting.
Motorola... | Answered on Jun 03, 2010
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Motorola... | Answered on May 06, 2010
hi,
Please try the default pass code "0000". If it does not work, please reply to me! i will help you!
Motorola... | Answered on Apr 02, 2010
Yes, you can pair your iPhone with any bluetooth headset. I have used many different Plantronics headsets and all have worked perfectly.
On the iPhone, go to Settings (the gears icon), click GENERAL, then Bluetooth and make sure it's switched to "On". Then, follow the pairing instructions that come with the headset.
Motorola... | Answered on Mar 17, 2010
Enter the code 10 times false, then your phone will reset himself and let create new one.
Motorola... | Answered on Feb 11, 2010
Here's the instructions for your headset. http://bit.ly/bpXysh
You'll find all the information you need to pair it, etc.
It's in PDF format. If you need a PDF Reader to view the page, you can download Adobe Reader for free:
Adobe Reader: http://get.adobe.com/reader/
Motorola... | Answered on Feb 04, 2010
Yep it will work, but you cant have Auto Answer facility in iphone.....Hav Paired the same with my motorola headset
Motorola... | Answered on Feb 03, 2010
Hi there - follow the step-by-step instructions here:
http://direct.motorola.com/eng/bluetoothselect.asp?country=GBR&am
Just pick your model and it will guide you through it;
Motorola... | Answered on Aug 29, 2009
normally it's 0000 on most of them
Motorola... | Answered on Aug 25, 2009
Motorola Mobility Bluetooth Headset-Silver/Black Headset Logo
55 questions posted
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Radio Communications
Most Popular Question
need pair number h700c
  • Radio Communications
