SOURCE: RCA RCU403 3-Device trying to control GPX DVD player???
It may not be able to run the GPX dvd player as GPX is not a mainstream brand, if you have the original GPX remote, you might purchase a learning remote that can copy remote codes from the original, I have seen these Learning Remotes from around $20 by Phillips Magnavox if I remember correctly.
SOURCE: i need a code for a gpx dvd player.
Here is a link for your manual
http://www.ofausa.com/remote_manual/URC4110%20manual%20booklet.QXD.pdf
Here is a list of codes. I dont see the GPX listed so try the code search function.Its on the manual.
http://www.ofausa.com/list_codes.php?db_value=access4&remote_choice=URC4110
SOURCE: durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
SOURCE: I need RCR3273R remote codes
I'm not sure you're going to be able to use that remote for that DVD. Philips / Magnavox remotes don't list codes for GPX equipment. I've managed to find a couple of codes that might work but no guarantees here:
0699 or 0769
Your best hope is to use the auto search function on the remote control. If that doesn't work, then it's unlikely the remote will work for you. Do you still have the instructions for programming the remote?
Please don't give me a low rating if these codes don't work. This is a difficult request and I've searched as many sources as I can find. Thanks.
SOURCE: I have an auvio 15-304
i have an Auvio 15-305, so this might help. Manual Code Search.
1) Power on the device that you want to control. For VCR and DVD players, you must insert a tape or disc first.
2) Press and hold SET, then press (TV, VCR/DVD, AUD, DVR,SAT/CBL, AUX) at the same time on the remote. The LED will stay lit indicating it is on setup mode. NOTE: DO NOT HOLD DOWN THE KEYS MORE THAN 3 SECONDS OR THE REMOTE ENTERS AUTO SEARCH MODE.
3) Press POWER on the remote. The remote enters a manual code search mode, the LED will start flashing.
4) Press POWER on the remote continuously until the device turns off.
5) When it turns off, turn on the device manually. then try pressing the other buttons on the remote except for the POWER, SET, and DEVICE keys.
If most of the buttons work then press the selected DEVICE key that you selected in Step 2.
i hope this helps.
Remote
control codes:http://www.xdiv.com/remotes/
http://www.remotecodelist.com/remotes/rca/rca.htm
