Receipt won't print after paper change (and it IS thermal...)
Well that's it... we changed the receipt paper and the printer stopped printing completely, even with the thermal paper, and with the paper coming from bottom... and the journal still print...
did you accidently turn off the print function? sounds silly but sometimes it happensdid you accidently turn off the print function? sounds silly but sometimes it happens
You can't post conmments that contain an email address.
I got mine to work by changing the port from USB001 to USB002 prints great now, there is problems with installing on windows 8, you have to disable driver verification or the driver won't install.
There are various responses regarding the operation of the printer on the Omni. Use the
following to guide you through resolving this problem.
Terminal Response
Probable Cause
Action Taken
No Receipt Prints
Terminal is out of paper.
Load paper and/or verify that the paper is installed correctly.
Motor on printer is defective.
Have terminal serviced.
For Vx-6xx terminals only, insufficient charge remaining in the battery to
complete the print operation.
Check battery status and recharge if neccessary.
Receipt Feeds, But Nothing Is Printed
On It
Not using thermal paper.
Ensure thermal paper is being used.
Thermal paper loaded upside down.
Ensure thermal paper is being fed from underneath the roll, as it will only
print on one side of the paper.
On It
Our Star TSP700II leaves about 1/4 inch of unused paper on the roll when the error light comes on and the printer stops printing. Is there any way we can make an adjustment so that we're not wasting so much paper?
