Magic Chef MCBR440 Compact Refrigerator Logo
Posted on Aug 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge won't start, tries to but clicks off after a few seconds
Model MCBR360S Magic Chef mini fridge
Clicks on and begins humming, only to click off again 15 or so seconds later. Compressor is running hot.
How can I diagnose the problem?
Matthew MacWilliams
Level 2:
Sniper:
  • Expert 97 Answers
  • Posted on Aug 26, 2009
Matthew MacWilliams
Expert
Level 2:
Sniper:
Answers
97
Questions
0
Helped
31127
Points
282
Compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
MAGIC CHEF MCBR 360S Mini Fridge and compressor is not working or cooling. No sound at all from unit. See more details below please. Thank you!
The compressor being hot means it is getting power to it. 2 possible problems. The compressor is locked up internally (too expensive) or the start relay or overload could be bad (approx cost for both parts about $45). You have to decide if you want to risk $50 and still find out you have a bad compressor. Most service techs have a direct test harness to hook up to compressors and make them run without the start relay and overload but not everyone knows how to do it properly.
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Fridge won't cool
then its not a fridge its a cupboard,
I have Model No. MCBR360S Mini Refrigerator- It Quit working - The compressor was pretty warm. I keep hearing a Click.
That clicking sound is the compressor trying to start, if it is less than a year old just call magic chef and they will replace the unit, if not the cost of a sealed system repair may make it not worth reairing
5helpful
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
9helpful
Magic Chef mini fridge stopped working. I hear a click to start but within a minute it clicks again. Keeps repeating this over and over.
You have either a bad capacitor or a bad compressor. If I were there I would put a part on called a 3 in 1. It's made by Supco. It replaces your relay Overload and start capacitor. If the compressor is good, it will fix your problem. Click on this site and you will see the part I'm talking about. It's very simple to put on. http://www.appliancepartsonline.net/index.php?target=categories&category_id=50 The part number is RCO410
Please rate this solution and good luck!
2helpful
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
2helpful
Fridge won't run
hi brenda,
can u hear a humming sound as if it is trying to start then it would stop after a clicking sound?
if it does then it is your compressor trying to start but can not do it.
you could either have a problem in your starting relay of overload protector of the compressor or the compressor itself is the defective part and it needs to be replaced.
i hope i was able to help.
pls rate me
tnx
drcool
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
