20 Most Recent
Haier HSW02C Questions & Answers
I have a haier mini fridge model #HSW02C when i
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
10/13/2013 9:43:21 AM •
Haier HSW02C
Answered
on Oct 13, 2013
Haier refrigerator hsw02c does not run
These are pretty simple units. If you look on the back you will see a schematic. More or less there is an overload protector in series with the thermostat in series with the compressor. If the overload protector is not open and there is still no 120VAC at the compressor with the thermostat turned all the way up then the answer is a bad thermostat. If there is 120VAC at the compressor and it is not running then the compressor is bad. That's about it.
8/15/2013 12:03:30 PM •
Haier HSW02C
Answered
on Aug 15, 2013
Haier mini fridge model hswo2c not working
on its side? considering the chemicals inside the freezing elements, it needs to sit upright for 24 hours before you plug it in, or you may break it. so if thats what you mean, why is it sideways?
11/26/2010 9:04:12 AM •
Haier HSW02C
Answered
on Nov 26, 2010
The freezer in my Haier
Well first of all let us know that from where it leaks - from the bottom front of the refrigerator or freezer door, from the back of the refrigerator, from the inside ceiling of the refrigerator, from the inside back wall of the refrigerator
Underneath the front of the refrigerator. Please reply for mode help or information.........
Thanks
2/4/2010 6:13:33 PM •
Haier HSW02C
Answered
on Feb 04, 2010
Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
7/12/2007 6:28:27 PM •
Haier HSW02C
Answered
on Jul 12, 2007
Fan Not Coming On & Compressor Is Hot
Ckecked around for the fan, parts for this unit are few and far between did locate some on ebay so head over there. Cuz there were quite a few but without seeing yours I couldn't match up what I was seeing.
1/22/2023 3:49:52 PM •
Haier...
Answered
on Jan 22, 2023
My haier 10.5 model 10TG31SW is not cooling neither top or bottom any clues
If your Haier 10.5 model 10TG31SW refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can check:
- Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
- Check the condenser coils: The condenser coils may be dirty or clogged, preventing the refrigerator from cooling properly. Clean the coils with a brush or vacuum.
- Check the door seal: Make sure the door seal is tight and not damaged. If the seal is not tight, cold air will escape and the refrigerator will not cool properly.
- Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the refrigerator not to cool.
- Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. It may need to be replaced by a professional.
- Check the refrigerant level: If the refrigerant level is low, it can cause the cooling system to fail. This is a job that should be done by a professional with the right equipment and experience.
- Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
- Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
1/22/2023 3:20:45 PM •
Haier...
Answered
on Jan 22, 2023
Is there any way I can delete the alarm beep when doors are left open on my new Haier fridge HSBS610IS please?
It depends on the model of your Haier refrigerator. Many newer models of Haier refrigerators have a feature to disable the alarm beep when the doors are left open. To disable the alarm beep, you will need to check the user manual of your refrigerator for specific instructions on how to do this, as the process may vary depending on the model.
Here are a few general steps that could help you to disable the alarm beep:
- Look for a button or switch labeled "alarm" or "door alarm" on the control panel of your refrigerator.
- Press and hold the button or switch for a few seconds until the alarm stops beeping. This should disable the door alarm.
- In some models, you can disable it through the settings menu of the control panel, look for the alarm setting and turn it off.
- Look for the manual of your refrigerator, it should have the information on how to do it.
If you can't find a way to disable the alarm beep, or you are not comfortable with following the instructions, it's best to contact the manufacturer or a professional for further assistance.
1/22/2023 3:18:34 PM •
Haier...
Answered
on Jan 22, 2023
The wire that fixes to freezer compartment with a metal prong has come adrift
It sounds like the wire you're describing is the defrost thermostat. The defrost thermostat is responsible for controlling the defrost cycle of the refrigerator. The flat piece of metal with hooks at each end that you mentioned is likely the clip that attaches the thermostat to the evaporator coils in the freezer compartment.
To reattach the thermostat, you will need to follow these steps:
- Locate the evaporator coils in the freezer compartment. The coils are typically located in the back of the freezer.
- Carefully place the hooks of the clip onto the evaporator coils.
- Insert the metal prong on the end of the thermostat wire into the clip.
- Ensure the wire is properly seated in the clip and that the clip is securely fastened to the evaporator coils.
- Put back the cover panel of the freezer compartment
- Check that the thermostat wire is not pinched or crimped and that it has enough slack to move freely.
- Plug the refrigerator back in and turn it on.
It's important to note that working with the refrigeration system could be dangerous and it's always recommended to contact a professional if you're not comfortable with the task.
1/22/2023 3:12:11 PM •
Haier...
Answered
on Jan 22, 2023
