During night in water bilge area and half boat fuul of water
All boats (except ProStar) have two drain plugs, which allow water to be drained from the boat when the boat is OUT of the water. There is a center T-handle drain (the only one for a ProStar) and a transom drain plug. The lower plug is located in the center of the transom at the lowest point. It will be under water when the boat is in the water.
SOURCE: 1998 Champion 181 bass boat in California...It
try "duct tape" the fittings and drain to seal those areas, refill and see if water is still leaking, if so it's your live-well is cracked somewhere, and can be repaired on the inside with fiberglass resin..... if not then most likely the fittings/pump/hoses/etc....yes its a pain .Champions don't have alot of room to access any of that...got a Ranger myself....hope this helps and see you on the water....GL
SOURCE: Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
SOURCE: alarm/buzzer going off without shutting off
that could be the engine fault alarm, if its a Mercury that indicates high engine temp, low oil pressure (4stroke) low oil level (2 stroke and 4 stroke) Either way, dont ignore it, it will get expensive. this information is similar for Yamahas as well
SOURCE: I am trying to find a wiring diagram for a bass
I did some looking/researching and came up with this forum page.
http://www.google.com/imgres?imgurl=http://www.myciscolab.com/images/Console%2520Wiring.gif&imgrefurl=http://forums.iboats.com/showthread.php%3Ft%3D310696&usg=__FA-R1oUs-id8UOkHGzrgcxew1Wg=&h=769&w=1126&sz=53&hl=en&start=72&sig2=UaxFRn0_4iFUgvLHJG3h7g&um=1&itbs=1&tbnid=LlYhRHmxH6poCM:&tbnh=102&tbnw=150&prev=/images%3Fq%3Dbass%2Btracker%2Bboat%2Bwiring%26start%3D60%26um%3D1%26hl%3Den%26sa%3DN%26ndsp%3D20%26tbs%3Disch:1&ei=pRQpTMMZn7OcB-Tk9YYB
I did the best I could with the information I had. Please leave 4 thumbs up! if you comment or add more details I'll see what I can do with new information.
SOURCE: how often do i drain water, i have air conditioner
Hourly if it is above a 100 degrees but you will know when to empty it because it will shut off if it gets full.
