I've had this TV hooked up to an HD cable box (using the TV's "component" inputs) for several years and everything has worked just fine. Last week I moved the TV to my guest cottage which has no cable service. After hooking up an external (rooftop) antenna, I attempted to scan for the local OTA HDTV channels. The analog channel scan went as it should. (Of course, there were no analog channels to be found!) Once the analog portion of the scan was completed, however, the screen went blank and no digital channels were ever detected. I tried unplugging the set and plugging it back in, etc. all to no avail. Does anyone know what's wrong with the digital tuner on my JVC LT-32X667?
Thanks in advance for any assistance.
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Yes, I most definitely selected "air" and not "cable" on the JVC's drop down menu.
Thank you.
Are you sure that you selected off the air channel scanning as opposed to cable channel scanning?
